Kicker DS68.2 DS Series 6" x 8" Component Speaker System
Brand:|Model: 11DS68.2|Part # 267-6947
Kicker's DS Series component speaker systems provide an instant upgrade to "premium" factory speakers and are designed to work seamlessly with Kicker subwoofers. The DS68.2 6" x 8" component speaker system adds rear fill and bass that stock speakers simply can't provide.
Ships in 7-10 Business Days
List Price$169.95
You Save29%
Part # 267-6947
  • 6" x 8" poly woofer with heavy-duty motor and built-in phase plugs
  • 3/4" titanium dome tweeter with three mounting options
  • 4 kHz 2-way crossover with three tweeter attenuation settings
  • 40 to 21,000 Hz frequency response and 45 watts RMS power handling
Frequently Bought Together
Upgrading your factory speakers (even so-called premium sound systems, by vehicle manufacturers) and providing a superior complement to a subwoofer—without breaking the bank—is what the Kicker's DS Series component speaker systems are all about. Trademark Kicker heavy-duty motor structures and EVC™ (Extended Voice Coil) technology make their way into the woofers for real-world power handling and every DS Series system produces great performance and music realism.
Trademark Kicker Woofer Design
The Kicker DS68.2 component speaker system features sturdy 6" x 8" polypropylene woofers with ribbed, UV-treated surrounds, and built-in phase plugs to not only keep excursion linear for clean bass and quick transients, but also for butter smooth midrange response and increased dispersion. Reduced woofer mounting depth means one thing—these woofers make for an easy upgrade in a vehicle’s doors or kick panels.
Crystal Clear Highs with Advanced Crossover Options
3/4" titanium dome tweeters, with oversized voice coils, strike a perfect design balance with the woofers, adding just the right amount of crisp, clean highs. Three tweeter mounting options—flush, angled, and surface mounting—allow for easy interior integration on your car doors, A-pillars, or dash.
Seamless driver integration is handled by the included crossover network. 4,000 Hz, 12 dB/octave high and low-pass filters keep each driver focused on the frequencies they play best. Three tweeter attenuation settings of 0 dB, -3 dB, and -6 dB tailor its output based on the installation location you choose.
Specifications: • Power handling: 45 watts RMS/90 watts peak • Impedance: 4 ohms • Frequency response: 40-21,000 Hz • SPL: 90 dB • Crossover point: 4,000 Hz (12 dB/octave) • Woofer dimensions: Cone size: 6" x 8", Cutout: 5" x 7-3/16", Mounting depth: 2-3/8"" • Tweeter dimensions: Dome size: 3/4" dia., Flush mount cutout: 2-3/16" dia., Flush mount depth: 1-9/16" • Crossover dimensions: 4-7/8" L x 2.5" W x 1-3/8" H.
Inside the box you'll find:
• Two 6" x 8" woofers
• Two woofer grills
• Two 3/4" tweeters with 3 ft. of wire pre-attached
• Two crossovers with 34" of wire pre-attached to tweeter input and woofer output
• Six tweeter mounting rings (two flush, two front angle, two back angle)
• Four tweeter mounting nuts (two short, two long)
• Eight 1" self-tapping screws
• Four 1-1/8" self-tapping screws
• Two 5/8" self-tapping screws
• Four butt connectors
• Eight speed clips
• Four 7-1/2" cable ties
• Owners manual
The DS Series is available in three models featuring a trio of woofer sizes, including the DS6.2 with 6" woofers, the DS65.2 with 6-1/2" woofers, and the DS68.2 that fits 6" x 8" or 5" x 7" factory locations, found in specific vehicles.
Kicker Authorized Badge
  • BrandKicker
  • Model11DS68.2
  • Part Number267-6947
  • UPC713034055259
  • Product CategoryComponent Speaker Systems
  • Weight5.85 lbs.
View similar products to the Kicker DS68.2 DS Series 6" x 8" Component Speaker System
in the Component Speaker Systems product category.
