Kicker CVX152 CompVX Series 15" DVC Subwoofer 2+2 Ohm
Brand:|Model: 10CVX152|Part # 267-6930
Kicker's CompVX Series of DVC subwoofers use the same technology found in the Solo-Baric L7 for maximum performance. The CVX152 dual 2 ohm 15" subwoofer is built to handle up to 1,000 watts of pure power in box sizes as small as 1.8 cubic feet.
ORDER TODAY
Ships in 7-10 Business Days
List Price$449.95
You Save11%
$399.95
Part # 267-6930
  • 1,000 watt RMS power handling
  • Designed for sealed enclosures 1.8 to 5.2 cubic feet and ported enclosures 3 to 5 cubic feet
  • Dual 2 ohm voice coils for stereo 2 ohm, parallel 1 ohm, and series 4 ohm wiring configurations
  • Kicker''s most powerful 15" round subwoofer
Kicker® takes the maximum performance and power of their patented square-woofer technology and packs it into the round CompVX™ Series subwoofers, creating the most technologically advanced round subwoofer available. CompVX subwoofers are the best-sounding, deepest-bass-producing round subwoofers that Kicker has ever offered.
The CVX152 15" dual 2 ohm subwoofer uses all of the exclusive Solo-Baric® L7 design and performance features. One-piece SoloKon™ cone with total back bracing for ultra rigidity, high temperature dual voice coils and a solid pole piece to subdue harmful heat, and a T-cut top plate for a wider magnetic field, stronger bass response, and better sound—it all comes together to form a super-reliable motor structure found only in a Kicker subwoofer.
Inside the subwoofer, a poly-cotton, semi-progressive-roll spider supports substantial excursion for the loudest bass possible. Externally, a ribbed Santoprene® surround allows for maximum excursion while resisting wear. CompVX’s basket is cast aluminum with motor-cooling perimeter venting and spring-loaded terminals that can accept up to 10 AWG wire.
The CompVX Series is available in 10", 12", and 15" sizes, and comes in 2 + 2 ohm or 4 + 4 ohm DVC configurations.
Kicker Authorized Badge
  • Nominal Diameter15"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)2000 Watts
  • Impedance2+2 ohms
  • Frequency Response18 to 500 Hz
  • Sensitivity91.6 dB 1W/1m
  • Resonant Frequency (Fs)23.7 Hz
  • Mechanical Q (Qms)7.52
  • Electromagnetic Q (Qes)0.22
  • Total Q (Qts)0.22
  • Compliance Equivalent Volume (Vas)5.5 ft.³
  • Maximum Linear Excursion (Xmax)17.4 mm
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.4375"
  • Baffle Cutout Diameter13.8125"
  • Depth8.5"
  • # Mounting Holes8
  • Sealed Volume0.41 ft.³
  • Sealed F388 Hz
  • Vented Volume0.75 ft.³
  • Vented F359 Hz
  • BrandKicker
  • Model10CVX152
  • Part Number267-6930
  • UPC713034049760
  • Weight35 lbs.
View similar products to the Kicker CVX152 CompVX Series 15" DVC Subwoofer 2+2 Ohm
