Kicker CVX122 CompVX Series 12" DVC Subwoofer 2+2 Ohm
Brand:|Model: 10CVX122|Part # 267-6928
Kicker's CompVX Series of DVC subwoofers use the same technology found in the Solo-Baric L7 for maximum performance. The CVX122 dual 2 ohm 12" subwoofer is built to handle up to 750 watts of pure power in box sizes as small as 1 cubic foot.
List Price$349.95
You Save14%
$299.95
Part # 267-6928
  • 750 watt RMS power handling
  • Designed for sealed enclosures 1 to 4.6 cubic feet and ported enclosures 1.75 to 2.25 cubic feet
  • Dual 2 ohm voice coils for stereo 2 ohm, parallel 1 ohm, and series 4 ohm wiring configurations
  • Kicker''s most powerful 12" round subwoofer
Kicker® takes the maximum performance and power of their patented square-woofer technology and packs it into the round CompVX™ Series subwoofers, creating the most technologically advanced round subwoofer available. CompVX subwoofers are the best-sounding, deepest-bass-producing round subwoofers that Kicker has ever offered.
The CVX122 12" dual 2 ohm subwoofer uses all of the exclusive Solo-Baric® L7 design and performance features. One-piece SoloKon™ cone with total back bracing for ultra rigidity, high temperature dual voice coils and a solid pole piece to subdue harmful heat, and a T-cut top plate for a wider magnetic field, stronger bass response, and better sound—it all comes together to form a super-reliable motor structure found only in a Kicker subwoofer.
Inside the subwoofer, a poly-cotton, semi-progressive-roll spider supports substantial excursion for the loudest bass possible. Externally, a ribbed Santoprene® surround allows for maximum excursion while resisting wear. CompVX’s basket is cast aluminum with motor-cooling perimeter venting and spring-loaded terminals that can accept up to 10 AWG wire.
The CompVX Series is available in 10", 12", and 15" sizes, and comes in 2 + 2 ohm or 4 + 4 ohm DVC configurations.
Kicker Authorized Badge
  • Nominal Diameter12"
  • Power Handling (RMS)750 Watts
  • Power Handling (max)1500 Watts
  • Impedance2+2 ohms
  • Frequency Response20 to 500 Hz
  • Sensitivity87.1 dB 1W/1m
  • Resonant Frequency (Fs)28.5 Hz
  • Mechanical Q (Qms)10.1
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)2.04 ft.³
  • Maximum Linear Excursion (Xmax)15.4 mm
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.5625"
  • Baffle Cutout Diameter11.0625"
  • Depth6.6875"
  • # Mounting Holes8
  • Sealed Volume0.59 ft.³
  • Sealed F359 Hz
  • Vented Volume1.42 ft.³
  • Vented F333 Hz
  • BrandKicker
  • Model10CVX122
  • Part Number267-6928
  • UPC713034049784
  • Weight23 lbs.
View similar products to the Kicker CVX122 CompVX Series 12" DVC Subwoofer 2+2 Ohm
