Kicker CVT102 CompVT Series 10" Subwoofer 2 Ohm
Brand:|Model: CVT102|Part # 267-6916
For quality Kicker bass in tight places, choose CompVT Series subwoofers. The CVT102 10" 2 ohm subwoofer not only handles 400 watts of RMS power, it features a mounting depth of less than 4-1/2"!
Part # 267-6916
  • 4-1/4" mounting depth makes the CVT102 great for bass in tight places
  • 400 watts RMS power handling and 2 ohm impedance
  • Stitched Santoprene surround and 4-layer voice coil stand the test of time... even against extreme use!
Who wouldn’t want a subwoofer that slams from the slimmest locations? Kicker®'s high-performance CompVT™ Series subwoofers feature a reduced mounting depth for sliding into door panels and space limited locations such as under a car seat.
Precise Kicker engineering makes the CompVT pound with limited space: a unique four-layer voice coil provides serious power handling without bulk, and a stiff injection-molded, modified-spoke cone is shaped to provide maximum excursion from a slender basket. These features combine to create a line of subwoofers with less than 4-1/2" of mounting depth without sacrificing bass output!
A solid pole piece design allows all CompVT subwoofers to be mounted directly against the rear wall of an enclosure, while the spring-loaded binding posts are mounted horizontally to minimize size. Lastly, Kicker includes a steel adapter plate that replaces part of a cabinet's back wall, for an even thinner subwoofer profile!
Each Kicker CVT102 10" 2 ohm subwoofer features a 360° back braced cone, ribbed Santoprene® surround, and Spiralead™ tinsel-lead technology to make it sound spectacular. Perimeter venting, high-temp coil wire, double-stitching, and a logo trim ring around the steel basket’s outer edges are built-in for longevity and driver durability.
Three different sized CompVT subwoofers are available in (2 ohm or 4 ohm impedances) to deliver real Kicker bass. The 12" CVT12 and 10" CVT10 subwoofers easily handle 400 watts RMS (800 watts peak) without hesitation, and if you want to go even smaller, a 6-1/2" option hammers from the slimmest locations.
compvt_comparison
Kicker Authorized Badge
  • Nominal Diameter10"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance2 ohms
  • Frequency Response25 to 350 Hz
  • Sensitivity87.2 dB 1W/1m
  • Resonant Frequency (Fs)32.7 Hz
  • Mechanical Q (Qms)9.56
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.44
  • Compliance Equivalent Volume (Vas)1.3 ft.³
  • Maximum Linear Excursion (Xmax)9.2 mm
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.6875"
  • Baffle Cutout Diameter9.1875"
  • Depth4.25"
  • # Mounting Holes8
  • Sealed Volume0.54 ft.³
  • Sealed F359 Hz
  • Vented Volume1.41 ft.³
  • Vented F330 Hz
  • BrandKicker
  • ModelCVT102
  • Part Number267-6916
  • UPC713034049890
  • Weight11 lbs.
View similar products to the Kicker CVT102 CompVT Series 10" Subwoofer 2 Ohm
