Kicker CVR152 CompVR Series 15" DVC Subwoofer 2+2 Ohm
Brand:|Model: 10CVR152|Part # 267-6924
Kicker's CompVR line of subwoofers feature extreme power handling and won't break your budget. The CVR152 15" DVC subwoofer is built with two 2 ohm voice coils for use with high current amplifiers in parallel or stereo wiring configurations, or 4 ohm amplifiers when wired in series.
Part # 267-6924
  • 500 watts RMS power handling
  • Dual 2 ohm voice coils for stereo 2 ohm, parallel 1 ohm, or series 4 ohm wiring configurations
  • Works in 1.8 to 5.2 cubic foot sealed enclosures and 3 to 5 ported enclosures
Frequently Bought Together
Kicker®'s CompVR® Series DVC subwoofers deliver high performance and power handling with superior bass technology exceeding anything else in its class—the cornerstone from which all legendary Kicker bass is chiseled.
CompVR subwoofers come from a long line of excellence, evolving from the tough-as-nails Kicker Competition subwoofers back in the day. All CompVR subwoofers are engineered to the highest levels, and the line's unobtrusive look will have any installation primed to perform.
The CVR152 15" 2 + 2 ohm dual voice coil subwoofer has a spoked, injection-molded cone which completely eliminates flex and distortion using 360° back bracing. Kicker Solo-Baric® technology trickles down into the overall motor structure, allowing the sub to handle more power and withstand more abuse with a solid pole piece for superb heat dissipation. The progressive-roll, poly-cotton spider and steel basket’s perimeter venting assure absolute heat dissipation without breakdown.
CompVR subwoofers use high-temperature voice coils, a ribbed Santoprene® surround (that gives the cone added strength at high excursions), Spiralead™ tinsel-lead technology, and spring-loaded push terminals are part of the high-performance engineering standards found on every Kicker woofer.
Available in three different sizes (10", 12", and 15"), and two different impedances (2 + 2 and 4 + 4 ohm).
Kicker Authorized Badge
  • Nominal Diameter15"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance2+2 ohms
  • Frequency Response25 to 500 Hz
  • Sensitivity89.2 dB 1W/1m
  • Resonant Frequency (Fs)24.6 Hz
  • Mechanical Q (Qms)9.14
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)5 ft.³
  • Maximum Linear Excursion (Xmax)12.5 mm
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.6875"
  • Depth8.1875"
  • # Mounting Holes8
  • Sealed Volume1.43 ft.³
  • Sealed F351 Hz
  • Vented Volume3.43 ft.³
  • Vented F329 Hz
  • BrandKicker
  • Model10CVR152
  • Part Number267-6924
  • UPC713034050049
  • Weight29 lbs.
View similar products to the Kicker CVR152 CompVR Series 15" DVC Subwoofer 2+2 Ohm
