Kicker CVR124 CompVR Series 12" DVC Subwoofer 4+4 Ohm
Brand:|Model: CVR124|Part # 267-6923
Kicker's CompVR line of subwoofers feature extreme power handling and won't break your budget. The CVR124 12" DVC subwoofer is built with two 4 ohm voice coils for use with high current amplifiers when wired in parallel, or 8 ohm amplifiers when wired in series.
- Order Soon - Only 3 Left In Stock
List Price$189.95
You Save32%
$129.95
Part # 267-6923
  • 400 watts RMS power handling
  • Dual 4 ohm voice coils for stereo 4 ohm, parallel 2 ohm, or series 8 ohm wiring configurations
  • Works in 1 to 4.6 cubic foot sealed enclosures and 1.75 to 2.25 ported enclosures
Kicker®'s CompVR® Series DVC subwoofers deliver high performance and power handling with superior bass technology exceeding anything else in its class—the cornerstone from which all legendary Kicker bass is chiseled.
CompVR subwoofers come from a long line of excellence, evolving from the tough-as-nails Kicker Competition subwoofers back in the day. All CompVR subwoofers are engineered to the highest levels, and the line's unobtrusive look will have any installation primed to perform.
The CVR124 12" 4 + 4 ohm dual voice coil subwoofer has a spoked, injection-molded cone which completely eliminates flex and distortion using 360° back bracing. Kicker Solo-Baric® technology trickles down into the overall motor structure, allowing the sub to handle more power and withstand more abuse with a solid pole piece for superb heat dissipation. The progressive-roll, poly-cotton spider and steel basket’s perimeter venting assure absolute heat dissipation without breakdown.
CompVR subwoofers use high-temperature voice coils, a ribbed Santoprene® surround (that gives the cone added strength at high excursions), Spiralead™ tinsel-lead technology, and spring-loaded push terminals are part of the high-performance engineering standards found on every Kicker woofer.
Available in three different sizes (10", 12", and 15"), and two different impedances (2 + 2 and 4 + 4 ohm).
Kicker Authorized Badge
  • Nominal Diameter12"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance4+4 ohms
  • Frequency Response25 to 500 Hz
  • Sensitivity86.9 dB 1W/1m
  • Resonant Frequency (Fs)32.6 Hz
  • Mechanical Q (Qms)8.17
  • Electromagnetic Q (Qes)0.7
  • Total Q (Qts)0.65
  • Compliance Equivalent Volume (Vas)2.3 ft.³
  • Maximum Linear Excursion (Xmax)12.73 mm
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.625"
  • Baffle Cutout Diameter11"
  • Depth6.25"
  • # Mounting Holes8
  • Sealed Volume3.87 ft.³
  • Sealed F340 Hz
  • Vented Volume6.05 ft.³
  • Vented F321 Hz
  • BrandKicker
  • ModelCVR124
  • Part Number267-6923
  • UPC713034050070
  • Weight17 lbs.
View similar products to the Kicker CVR124 CompVR Series 12" DVC Subwoofer 4+4 Ohm
