Kicker C15D4 Comp Series 15" DVC Subwoofer 4+4 Ohm
Brand:|Model: 10C15D4|Part # 267-6913
Kicker's C15D4 15" dual 4 ohm voice coil Comp Series subwoofer is all about amplifier wiring versatility and future-proofing your subwoofer system.
- Order Soon - Only 3 Left In Stock
List Price$179.95
You Save33%
$119.95
Part # 267-6913
  • 300 watts RMS power handling
  • Dual 4 ohm voice coils for wiring flexibility
  • Works in sealed enclosures from 2.25 to 5 cubic feet and ported enclosures from 3 to 4 cubic feet
Kicker Comp™ Subwoofer Series delivers the best bass for the buck! Legendary Kicker bass and possibly the world’s greatest value for under $120. This Comp Series is the best balance between high value and high performance in Kicker’s lineup. All Comp Series subwoofers are versatile, performing in vented or sealed enclosures, and in free-air applications as well.
The C15D4 Comp Series 15", DVC subwoofer is equipped with all of the proven Kicker construction that you find in elite Kicker woofers, including: the stiffest injection-molded cone with flex-killing 360° back bracing, coil cooling perimeter venting, high-temp voice coil wire, and Spiralead™ tinsel-lead technology for ultimate durability.
Easy-to-use nickel-plated push terminals, a resilient steel basket, and yellow double-stitched surround make Kicker's C15D4 subwoofer look as good as it sounds. If all of this isn't enough... the C15D4 leaves enough cash left over to throw down on a powerful Kicker amplifier to unlock optimum subwoofer performance.
Available in four different sizes (8", 10", 12" and 15"), three different impedances (2, 4, and 8 ohm), with dual voice coil variants also available in 12" and 15" sizes.
Kicker Authorized Badge
  • Nominal Diameter15"
  • Power Handling (RMS)300 Watts
  • Power Handling (max)600 Watts
  • Impedance4+4 ohms
  • Frequency Response25 to 500 Hz
  • Sensitivity90.3 dB 1W/1m
  • Resonant Frequency (Fs)23 Hz
  • Mechanical Q (Qms)9.61
  • Electromagnetic Q (Qes)0.42
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)7.99 ft.³
  • Maximum Linear Excursion (Xmax)11.4 mm
  • Cone MaterialPoly
  • Surround MaterialFoam
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.6875"
  • Depth7.4375"
  • # Mounting Holes8
  • Sealed Volume2.57 ft.³
  • Sealed F346 Hz
  • Vented Volume6.47 ft.³
  • Vented F325 Hz
  • BrandKicker
  • Model10C15D4
  • Part Number267-6913
  • UPC713034053224
  • Weight18.1000 lbs.
View similar products to the Kicker C15D4 Comp Series 15" DVC Subwoofer 4+4 Ohm
