Kicker C12D4 Comp Series 12" DVC Subwoofer 4+4 Ohm
Brand:|Model: C12D4|Part # 267-6909
Kicker's C12D4 12" dual 4 ohm voice voil Comp Series subwoofer is designed for amplifier wiring flexibility!
List Price$129.95
You Save38%
$79.95
Part # 267-6909
  • 200 watts RMS power handling
  • Dual 4 ohm voice coil for wiring flexibility
  • Works in sealed enclosures from 1.25 to 3.5 cubic feet and ported enclosures from 1.75 to 2.25 cubic feet
Kicker Comp™ Subwoofer Series delivers the best bass for the buck! Legendary Kicker bass and possibly the world’s greatest value for under $100. The Comp Series is the best balance between high value and high performance in Kicker’s lineup. All Comp Series subwoofers are versatile, performing in vented or sealed enclosures, and in free-air applications as well.
The C12D4 Comp Series 12", DVC subwoofer is equipped with all of the proven Kicker construction that you find in elite Kicker woofers, including: the stiffest injection-molded cone with flex-killing 360° back bracing, coil cooling perimeter venting, high-temp voice coil wire, and Spiralead™ tinsel-lead technology for ultimate durability.
Easy-to-use nickel-plated push terminals, a resilient steel basket, and yellow double-stitched surround make Kicker's C12D4 subwoofer look as good as it sounds. If all of this isn't enough... the C12D4 leaves enough cash left over to throw down on a powerful Kicker amplifier to unlock optimum subwoofer performance.
Available in four different sizes (8", 10", 12" and 15"), three different impedances (2, 4, and 8 ohm), with dual voice coil variants also available in 12" and 15" sizes.
Kicker Authorized Badge
  • Nominal Diameter12"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance4+4 ohms
  • Frequency Response27 to 500 Hz
  • Sensitivity88.3 dB 1W/1m
  • Resonant Frequency (Fs)27 Hz
  • Mechanical Q (Qms)10.22
  • Electromagnetic Q (Qes)0.59
  • Total Q (Qts)0.56
  • Compliance Equivalent Volume (Vas)3.36 ft.³
  • Maximum Linear Excursion (Xmax)9.6 mm
  • Cone MaterialPoly
  • Surround MaterialFoam
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.63"
  • Baffle Cutout Diameter11"
  • Depth5.88"
  • # Mounting Holes8
  • Sealed Volume2.98 ft.³
  • Sealed F343 Hz
  • Vented Volume6.68 ft.³
  • Vented F321 Hz
  • BrandKicker
  • ModelC12D4
  • Part Number267-6909
  • UPC713034053231
  • Weight11.5 lbs.
View similar products to the Kicker C12D4 Comp Series 12" DVC Subwoofer 4+4 Ohm
