Kester 44 Rosin Core Solder 60/40 .031" 1 lb. Spool
Brand:|Model: 24-6040-0027|Part # 370-080
Kester "44" rosin core solder is designed for electronic and electrical work. It uses a fast acting, instant wetting, non-corrosive, and non-conductive flux for faster soldering and a strong, long lasting bond.
$30.68
Buy 4+$28.69
Part # 370-080
  • BrandKester
  • Model24-6040-0027
  • Part Number370-080
  • UPC768249061861
  • Product CategorySolder
  • Unit of MeasureRL
    (8 Reviews)
  • Weight1.386 lbs.
View similar products to the Kester 44 Rosin Core Solder 60/40 .031" 1 lb. Spool
in the Solder product category.
Kester 44 Rosin Core Solder 60/40 .031" 1 lb. Spool is rated 4.75 out of 5 by 8.
Rated 5 out of 5 by from Great Solder!This solder, combined with a quality soldering station such as the Weller WES50 with various sized tips, makes soldering projects a breeze. The Kester melts easily and always provides a good connection when soldered correctly. Sure, the Kester costs a bit more than some knock-off brands, but the peace of mind knowing you have the best is worth something. These 1/lb spools last forever... my last spool of Kester took me about 10 years to go through.
Date published: 2011-10-16
Rated 5 out of 5 by from Excellent SolderI did not have any problem getting this solder to melt and flow where I needed it while making the crossovers for my speakers.
Date published: 2010-02-10
Rated 5 out of 5 by from Kester 60/40 rosincoreIt's kester.. need I say more?
Date published: 2009-10-28
Rated 4 out of 5 by from GREAT SOLDERMelts fast, adheres well to the surface, Very clean solder with nice shimmer, very professional.
Date published: 2009-10-12
Rated 5 out of 5 by from best productneedless to post additional comments; every user knows how good kester solders are.
Date published: 2009-10-10
Rated 5 out of 5 by from Top Quality SolderI have never gone wrong with Kester solder products
Date published: 2009-05-01
  • 2016-05-05T06:08CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_370-080, PRD, sort_mostRecent
which solder would be better to use for banana plugs and spades or xlr and rca the silver 4% stuff or this kester 44 with rosin core 60/40 stuff.. im thinking of getting a soldering station too the ssvt here at pe too.. for the job.. reasons why ?
Asked by: deltadoggy
Either option will work in the same way, there is a very slim chance you will hear any kind of difference between the normal 60/40 solder and 4% silver solder. I use 60/40 for all of my soldering regardless what it is, so whether the difference in price is justified will be up to you.
Date published: 2015-04-23
What is the temperature tolerance after the solder is on a joint.  I need to know after the solder has been applied what temperature range can this solder handle.  Thank you
Asked by: pereams
Unfortunately the manufacturer does not get very specific with the melting and flash points of this solder. The product MSDS simply states the melting point is >212F and the flash point is >199F. I would recommend contacting Kester for more information regarding this question.
What size for audio connectors(XLR, 1/4" plugs(TRS/TS)
I see this solder comes in several different diameters.Which size is best for audio connectors such as XLR and 1/4" plugs made by Neutrik and Switchcraft?
Asked by: adiaz28
0.031" is the most typical for audio connections and does not require hit heat to melt.
  • 2016-05-05T06:43CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • loc_en_US, sid_370-080, PRD, sort_recentQuestionsFirst
