Kenwood KFC-W3013PS Performance Series 12" 1200W Subwoofer
Brand:|Model: KFC-W3013PS|Part # 267-4356
Maximum bass for your buck is what Kenwood's Performance Series is all about. The Kenwood KFC-W3013PS 12" subwoofer handles up to 400 watts RMS and can be used in a sealed or ported enclosure.
Part # 267-4356
  • 400W RMS power handling
  • 12" subwoofer with 15.1 mm of Xmax, poly cone, and rubber surround
  • Works in sealed enclosures from 0.75 to 1.75 cubic feet
  • Works in ported enclosures from 1.5 to 2.0 cubic feet
  • Dual ventilation system for maximum heat dissipation
Kenwood's Performance Series subwoofers deliver maximum bass for your buck. A diamond array pattern reinforces the heavy-duty polypropylene cones which are mated to durable, tough butyl rubber surrounds to take the abuse from maximum excursion transients. The motor structure features a dual ventilation system to keep the voice coil cool.
Kenwood's 12" KFC-W3013PS subwoofer is designed for optimal use in 1.25 cubic foot sealed enclosures, but can be used in a sealed enclosure up to 1.75 cubic foot for deep bass or a sealed 0.75 cubic foot enclosures for tight bass. Ported enclosures of 1.5 to 2.0 cubic feet are fine as well.
  • Nominal Diameter12"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)1200 Watts
  • Impedance4 ohms
  • Frequency Response34 to 300 Hz
  • Sensitivity85 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight62.8 oz.
  • Resonant Frequency (Fs)25 Hz
  • DC Resistance (Re)3.4 ohms
  • Voice Coil Inductance (Le)1.65 mH
  • Mechanical Q (Qms)8.25
  • Electromagnetic Q (Qes)0.91
  • Total Q (Qts)0.82
  • Compliance Equivalent Volume (Vas)2.96 ft.³
  • BL Product (BL)10.5 Tm
  • Maximum Linear Excursion (Xmax)15.1 mm
  • Cone MaterialPoly
  • Overall Outside Diameter12.81"
  • Baffle Cutout Diameter11"
  • Depth6.19"
  • Bolt Circle Diameter11.85"
  • # Mounting Holes8
  • Sealed Volume6.85 ft.³
  • Sealed F326 Hz
  • Vented Volume12.43 ft.³
  • Vented F315 Hz
  • BrandKenwood
  • ModelKFC-W3013PS
  • Part Number267-4356
  • UPC019048192066
  • Product CategoryCar Subwoofer Speakers
    (3 Reviews)
  • Weight15.9 lbs.
View similar products to the Kenwood KFC-W3013PS Performance Series 12" 1200W Subwoofer
in the Car Subwoofer Speakers product category.
