Kenwood KFC-W2513PS Performance Series 10" 1000W Subwoofer
Brand:|Model: KFC-W2513PS|Part # 267-4354
Maximum bass for your buck is what Kenwood's Performance Series is all about. The KFC-W2513PS 10" subwoofer handles up to 300 watts RMS and can be used in a sealed or ported enclosure.
Part # 267-4354
  • 300W RMS power handling
  • 10" subwoofer with 5.3 mm of Xmax, poly cone, and rubber surround
  • Works in sealed enclosures from 0.4 to 1 cubic feet
  • Works in ported enclosures from 0.75 to 1.5 cubic feet
  • Dual ventilation system for maximum heat dissipation
Kenwood's Performance Series subwoofers deliver maximum bass for your buck. A diamond array pattern reinforces the heavy-duty polypropylene cones which are mated to durable, tough butyl rubber surrounds to take the abuse from maximum excursion transients. The motor structure features a dual ventilation system to keep the voice coil cool.
Kenwood's 10" KFC-W2513PS subwoofer is designed for optimal use in 0.65 cubic foot sealed enclosures, but can be used in a sealed enclosure up to 1 cubic foot for deep bass or a sealed 0.4 cubic foot enclosures for tight bass. Ported enclosures of 0.75 to 1.5 cubic feet are fine as well.
  • Nominal Diameter10"
  • Power Handling (RMS)300 Watts
  • Power Handling (max)1000 Watts
  • Impedance4 ohms
  • Frequency Response39 to 300 Hz
  • Sensitivity82 dB 1W/1m
  • Voice Coil Diameter2"
  • Magnet Weight43.4 oz.
  • Resonant Frequency (Fs)31 Hz
  • DC Resistance (Re)3.6 ohms
  • Voice Coil Inductance (Le)2.35 mH
  • Mechanical Q (Qms)8.24
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.54
  • Compliance Equivalent Volume (Vas)1.5 ft.³
  • BL Product (BL)11.2 Tm
  • Maximum Linear Excursion (Xmax)5.3 mm
  • Cone MaterialPoly
  • Overall Outside Diameter10.81"
  • Baffle Cutout Diameter9.13"
  • Depth5.19"
  • Bolt Circle Diameter9.88"
  • # Mounting Holes8
  • Sealed Volume1.22 ft.³
  • Sealed F345 Hz
  • Vented Volume2.82 ft.³
  • Vented F322 Hz
  • BrandKenwood
  • ModelKFC-W2513PS
  • Part Number267-4354
  • UPC019048192080
  • Product CategoryCar Subwoofer Speakers
  • Weight10.7 lbs.
View similar products to the Kenwood KFC-W2513PS Performance Series 10" 1000W Subwoofer
in the Car Subwoofer Speakers product category.
