Kenwood KFC-W12PS Performance Series 12" 1000W Subwoofer
Brand:|Model: KFC-W12PS|Part # 267-4355
Maximum bass for your buck is what Kenwood's Performance Series is all about. The KFC-W12PS 12" subwoofer handles up to 250 watts RMS and can be used in a sealed or ported enclosure.
List Price$120.00
You Save17%
Buy 2+$68.00
Part # 267-4355
  • 250W RMS power handling
  • 12" subwoofer with 7.35 mm of Xmax, poly cone, and foam urethane surround
  • Works in sealed enclosures from 0.75 to 1.75 cubic feet
  • Works in ported enclosures from 1 to 2 cubic feet
Kenwood's Performance Series subwoofers deliver maximum bass for your buck. A diamond array pattern reinforces the heavy-duty polypropylene cones which are mated to a durable, tough foam urethane to take the abuse from maximum excursion transients. The motor structure features a dual ventilation system to keep the voice coil cool.
Kenwood's 12" KFC-W12PS subwoofer is designed for optimal use in 1.25 cubic foot sealed enclosures, but can be used in a sealed enclosure up to 1.75 cubic foot for deep bass or a sealed 0.75 cubic foot enclosures for tight bass. Ported enclosures of 1 to 2 cubic feet are fine as well.
  • Nominal Diameter12"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)1000 Watts
  • Impedance4 ohms
  • Frequency Response36 to 300 Hz
  • Sensitivity85 dB 1W/1m
  • Voice Coil Diameter2"
  • Magnet Weight58.2 oz.
  • Resonant Frequency (Fs)33 Hz
  • DC Resistance (Re)3.1 ohms
  • Voice Coil Inductance (Le)2.3 mH
  • Mechanical Q (Qms)14.85
  • Electromagnetic Q (Qes)0.59
  • Total Q (Qts)0.57
  • Compliance Equivalent Volume (Vas)2.03 ft.³
  • BL Product (BL)13.6 Tm
  • Maximum Linear Excursion (Xmax)7.35 mm
  • Cone MaterialPoly
  • Overall Outside Diameter12.81"
  • Baffle Cutout Diameter11"
  • Depth6.48"
  • Bolt Circle Diameter11.85"
  • # Mounting Holes8
  • Sealed Volume1.96 ft.³
  • Sealed F346 Hz
  • Vented Volume4.17 ft.³
  • Vented F323 Hz
  • BrandKenwood
  • ModelKFC-W12PS
  • Part Number267-4355
  • UPC019048197627
  • Product CategoryCar Subwoofer Speakers
    (1 Reviews)
  • Weight12.45 lbs.
View similar products to the Kenwood KFC-W12PS Performance Series 12" 1000W Subwoofer
in the Car Subwoofer Speakers product category.
