Kenwood KAC-8405 4/3/2-Channel 720W Max Power Amplifier
Brand:|Model: KAC-8405|Part # 267-4206
Kenwood amplifiers are built upon trust. Each Kenwood amplifier features CEA-2006 Standard power output certifications so you can believe the power rating. The 4-channel KAC-8405 gives you up to 90W clean watts per channel (260W total, dual bridged mono) and sells for under $200.
Part # 267-4206
  • 60W x 4 CEA-2006 Standard certified power output at 4 ohms
  • Variable 50~200 Hz 2nd-order low-pass filter
  • Variable 50~200 Hz 2nd-order high-pass filter
  • Variable 0~18 dB bass boost centered at 40 Hz
  • Speaker-level and low-level RCA inputs with signal sensing turn-on
  • 2 ohm stereo stable and bridgeable at 4 ohms for 360W of output
Kenwood amplifiers are built to take the abuse of a demanding mobile audio system. Each amplifier is rated according to the CEA-2006 Standard so you know you can trust the power output listed for each amplifier, where many other amplifier manufacturers list the power output right before the amplifier goes into thermal shutdown.
For the sound quality (SQ) car audio enthusiast looking to drive their sound system with a single amplifier, the four-channel KAC-8405 amplifier delivers the superior sound quality that Kenwood's Performance Series amplifiers are known and bought for. The KAC-8405 delivers up to 360 watts of pure Kenwood power when bridged mono into two 4Ω loads (900W x 4 into 2Ω loads) making it perfect for driving all four door and dash speakers, and a subwoofer, or two subwoofers. A MOSFET power supply ensures that the Class AB power amplifier will be delivered efficiently without fail, and a cooling fan keeps the music going in extreme heat.
Built-in crossover filters, variable low-pass (50 to 200 Hz, 12 dB/octave) and variable high-pass (50 to 200 Hz, 12 dB/octave), customize the amplifier output so you’ll get the best sound possible from your subwoofer. Kenwood's KAC-8405 features cast aluminum heat sinks that are characteristic of Kenwood’s superior build quality. High quality RCA preamp and speaker-level inputs (with signal sensing turn-on) maintain signal integrity.
• CEA-2006 Standard power output: 60W x 4 @ 4Ω (0.08% THD+N, 20-20,000 Hz), 90W x 4 @ 2Ω (0.08% THD+N, 20-20,000 Hz)
• Rated power output (14.4 V): 180W x 2 @ 4Ω (1.0% THD+N, 1 kHz)
• Frequency response: 5-50,000 Hz (±3 dB)
• Input sensitivity: 0.2 to 5.0 V
• Input impedance: 10 kΩ
• Signal-to-noise ratio: 95 dB
• Low-pass filter (variable): 50~200 Hz, -12 dB/octave
• High-pass filter (variable): 50~200 Hz, -12 dB/octave
• Variable bass boost: 0-18 dB @ 40 Hz
• Dimensions (W x H x D): 11" x 2-5/16" x 9-3/8"
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)60 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels4
  • BrandKenwood
  • ModelKAC-8405
  • Part Number267-4206
  • UPC019048186485
  • Product CategoryCar Amplifiers
  • Weight6.8 lbs.
View similar products to the Kenwood KAC-8405 4/3/2-Channel 720W Max Power Amplifier
in the Car Amplifiers product category.
