Kenwood KAC-7205 Bridgeable 2-Channel 1000W Max Power Amp
Brand:|Model: KAC-7205|Part # 267-4202
Kenwood amplifiers are built upon trust. Each Kenwood amplifier features CEA-2006 Standard power output certifications so you can believe the power rating. The 2-channel KAC-7205 gives you up to 250W clean watts per channel (500W total) and sells for under $200.
Part # 267-4202
  • Less than a 50 cents per watt
  • 170W x 2 CEA-2006 Standard certified power output at 4 ohms
  • Variable 50 to 200 Hz 2rd-order low-pass filter
  • Speaker-level and low-level RCA inputs
  • 2 ohm stereo stable and bridgeable at 4 ohms for 500W of output
  • Dual cooling fans
  • Variable 0 to 18 dB @ 40 Hz bass boost
Kenwood amplifiers are built to take the abuse of a demanding mobile audio system. Each amplifier is rated according to the CEA-2006 Standard so you know you can trust the power output listed for each amplifier, where many other amplifier manufacturers list the power output right before the amplifier goes into thermal shutdown.
Sound quality (SQ) car audio enthusiasts buy Kenwood amps for their superior quality, and the KAC-7205 is no exception. The KAC-7205 delivers up to 500 watts of pure Kenwood power when bridged mono into a 4Ω load (250W x 2 into 2Ω loads) making it perfect for driving a stereo set of speakers, all four door and dash speakers, or a Kenwood Performance Series subwoofer. A MOSFET power supply ensures that the Class AB power amplifier will be delivered efficiently without fail. Dual cooling fans to keep the amplifier running in even the worst conditions.
The built-in, variable low-pass filter (50 to 200 Hz, 12 dB/octave) and variable 0 to 18 dB (@ 40 Hz) bass boost  optimizes the amplifier output so you’ll get the best sound possible from your subwoofer. Kenwood's KAC-7205 features cast aluminum heat sinks that are characteristic of Kenwood’s superior build quality. High quality RCA preamp and speaker-level inputs, with signal sensing turn-on, maintain signal integrity. Cool blue LED illumination lights up your installation location.
• CEA-2006 Standard power output: 170W x 2 @ 4Ω (1.0% THD+N, 20-20,000 Hz)
• Rated power output (14.4 V): 250W x 2 @ 2Ω (0.08% THD+N, 1 kHz), 500W x 1 @ 4Ω (0.08% THD+N, 1 kHz)
• Frequency response: 5-50,000 Hz (±3 dB)
• Input sensitivity: 0.2 to 5.0 V
• Input impedance: 10 kΩ
• Signal-to-noise ratio: 95 dB
• Low-pass filter (variable): 50~200 Hz, -12 dB/octave
• Bass boost (variable level): 0~18 dB @ 40 Hz
• Dimensions (W x H x D): 13-3/4" x 2-5/16" x 9-3/8"
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)170 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels2
  • BrandKenwood
  • ModelKAC-7205
  • Part Number267-4202
  • UPC019048187451
  • Product CategoryCar Amplifiers
  • Weight7.8 lbs.
View similar products to the Kenwood KAC-7205 Bridgeable 2-Channel 1000W Max Power Amp
in the Car Amplifiers product category.
