Kenwood KAC-7005PS 5-Channel 50Wx4 + 500Wx1 Amplifier
Brand:|Model: KAC-7005PS|Part # 267-4203
Kenwood amplifiers are built upon trust. Each Kenwood amplifier features CEA-2006 Standard power output certifications so you can believe the power rating. The 5-channel KAC-7005PS gives you up to 50W clean watts per channel (200W total), plus a dedicated 500W sub channel.
List Price$400.00
You Save13%
$349.98
Part # 267-4203
  • 40W x 4 + 300W x 1 CEA-2006 Standard certified power output at 4 ohms
  • Variable 50 to 200 Hz 4th-order low-pass filter
  • Variable 50 to 200 Hz 2nd-order high-pass filter
  • Speaker-level and low-level RCA inputs
  • 2 ohm stereo stable for 700W of total output
  • Cooling fan
  • Variable 0 to 18 dB @ 40 Hz bass boost
Kenwood amplifiers are built to take the abuse of a demanding mobile audio system. Each amplifier is rated according to the CEA-2006 Standard so you know you can trust the power output listed for each amplifier, where many other amplifier manufacturers list the power output right before the amplifier goes into thermal shutdown.
For the sound quality (SQ) car audio enthusiast looking to drive their sound system with a single amplifier, the four-channel KAC-7005PS amplifier delivers the superior sound quality that Kenwood's Performance Series amplifiers are known and bought for. The KAC-7005PS delivers up to 200 watts of pure Kenwood power when bridged mono into two 4Ω loads (50W x 4 into 2Ω loads) and a separate subwoofer channel that develops 500W into 2Ω loads, making it the perfect amplifier for driving your entire mobile audio system. A MOSFET power supply ensures that the Class AB power amplifier will be delivered efficiently without fail, with a cooling fan to keep the music playing in the worst heat conditions.
Built-in crossover filters, variable low-pass (50 to 200 Hz, -24 dB/octave) and variable high-pass (50 to 200 Hz, -12 dB/octave), customize the amplifier output so you’ll get the best sound possible from your subwoofer. Kenwood's KAC-7005PS features cast aluminum heat sinks that are characteristic of Kenwood’s superior build quality. High quality RCA preamp and speaker-level inputs maintain signal integrity.
• CEA-2006 Standard power output: 40W x 4, 300W x 1 @ 4Ω (1.0% THD+N, 20-20,000 Hz)
• Rated power output (14.4 V): 50W x 4 + 500W x 1 @ 2Ω (1.0% THD+N, 1 kHz), 100W x 2 + 300W x 1 @ 4Ω (1.0% THD+N, 1 kHz)
• Frequency response: 20-20,000 Hz (±1 dB)
• Input sensitivity: 0.2 to 5.0 V
• Input impedance: 10 kΩ
• Signal-to-noise ratio: 100 dB
• Low-pass filter (variable): 50~200 Hz, -24 dB/octave
• High-pass filter (variable): 50~200 Hz, -12 dB/octave
• Dimensions (W x H x D): 12-3/4" x 2-3/16" x 7-3/8"
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)40 + 300 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels5
  • BrandKenwood
  • ModelKAC-7005PS
  • Part Number267-4203
  • UPC019048197597
  • Product CategoryCar Amplifiers
  • Weight7.11 lbs.
View similar products to the Kenwood KAC-7005PS 5-Channel 50Wx4 + 500Wx1 Amplifier
in the Car Amplifiers product category.
Is the sub channel 1 ohm stable?
Asked by: Fred 69
All channels on this amp are only stable to 2 ohms.
Date published: 2015-11-27
With the kenwood kac-7005ps Bridge what is the watts out put difference?
Asked by: john john
When this amplifier is bridged it produces 100 watts RMS per channel (x2) into a 4 ohm load.
Date published: 2015-07-24
want to know if a kenwood kac-700 5p 5 channel will work  with a kenwood kfc-w2513ps performance series 10 inch sub
Asked by: bob69
Yes this will work fine with that woofer.
Date published: 2014-03-12
  • 2016-02-06T08:04CST
  • loc_en_US, sid_267-4203, PRD, sort_recentQuestionsFirst
