Kenwood KAC-2404S Bridgeable 4/3/2-Channel 500W Max Power Amp
Brand:|Model: KAC-2404S|Part # 267-4201
Kenwood amplifiers are built upon trust. Each Kenwood amplifier features CEA-2006 Standard power output certifications so you can believe the power rating. The 4-channel KAC-2404S gives you up to 60W clean watts per channel (260W total, dual bridged mono) and sells for under $150.
Part # 267-4201
  • Less than a dollar per watt
  • 40W x 4 CEA-2006 Standard certified power output at 4 ohms
  • Fixed 80 Hz 2rd-order high-pass filter
  • Variable 50~200 Hz 3rd-order low-pass filter
  • Speaker-level and low-level RCA inputs
  • 2 ohm stereo stable and bridgeable at 4 ohms for 230W of output
Kenwood amplifiers are built to take the abuse of a demanding mobile audio system. Each amplifier is rated according to the CEA-2006 Standard so you know you can trust the power output listed for each amplifier, where many other amplifier manufacturers list the power output right before the amplifier goes into thermal shutdown.
For the car audio enthusiast looking to drive their sound system with a single amplifier, the four-channel KAC-2404S amplifier delivers sound quality so good that you will never want to leave your car. The KAC-2404S delivers up to 260 watts of pure Kenwood power when bridged mono into two 4Ω loads (60W x 4 into 2Ω loads) making it perfect for driving all four door and dash speakers, and a subwoofer, or two subwoofers. A MOSFET power supply ensures that the Class AB power amplifier will be delivered efficiently without fail.
Built-in crossover filters, variable low-pass (50 to 200 Hz, 18 dB/octave) and fixed high-pass (80 Hz, 12 dB/octave), customize the amplifier output so you’ll get the best sound possible from your subwoofer. Kenwood's KAC-2404S features cast aluminum heat sinks that are characteristic of Kenwood’s superior build quality. High quality RCA preamp and speaker-level inputs maintain signal integrity.
• CEA-2006 Standard power output: 40W x 4 @ 4Ω (1.0% THD+N, 20-20,000 Hz)
• Rated power output (14.4 V): 60W x 4 @ 2Ω (1.0% THD+N, 1 kHz), 130W x 2 @ 4Ω (1.0% THD+N, 1 kHz)
• Frequency response: 5-50,000 Hz (±3 dB)
• Input sensitivity: 0.2 to 5.0 V
• Input impedance: 10 kΩ
• Signal-to-noise ratio: 95 dB
• Low-pass filter (variable): 50~200 Hz, -18 dB/octave
• High-pass filter (fixed): -12 dB/octave @ 80 Hz
• Dimensions (W x H x D): 13" x 2-3/16" x 8-7/16"
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)40 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels4
  • BrandKenwood
  • ModelKAC-2404S
  • Part Number267-4201
  • UPC019048192219
  • Product CategoryCar Amplifiers
  • Weight6.6 lbs.
View similar products to the Kenwood KAC-2404S Bridgeable 4/3/2-Channel 500W Max Power Amp
in the Car Amplifiers product category.
