CLEARANCE
245-8110_ALT_0
245-8110_ALT_1
JBL PRX712 12" 2-Way Powered PA Loudspeaker System
Brand:|Model: PRX712|Part # 245-8110
The PRX712 is a compact and versatile speaker in the PRX700 Series. It has been designed to deliver maximum performance as both a stage monitor and a front of house main PA. The PRX712 is a perfect match for a PRX powered sub, offering a high performance self-powered sub/sat system.
List Price$1,299.00
You Save46%
$699.00
Part # 245-8110
  • Maximum SPL output 135 dB peak
  • 12" Differential Drive® woofer
  • 1.5" annular polymer compression driver
  • 1,500 watt Class-D digital amplifier
  • DSP input section with dbx® Type IV™ limiter circuit, crossover, dynamic limiting
  • Professional XLR and 1/4" Mic/Instrument inputs, as well as RCA inputs
  • Integrated 36 mm dual-angle pole mount socket
JBL's PRX712 is an exceptionally small, light weight, versatile, and powerful tool to be added to the arsenal of any audio professional. The PRX700 Series represent an evolutionary step forward in the efficient use of amplifier power, rugged durability and enhanced versatility in a self-powered loudspeaker. Designed from the ground up to perform in the real world of sound reinforcement where challenging audio environments, high ambient noise levels and loud volumes are the norm, the PRX700 Series are built to last a lifetime using our reliable and trustworthy, tour-tested technology. Knowing you can rely on your system to deliver everything you need gives you the freedom to deliver your best. That's performance you can trust.
This 2-way 12" gem offers the perfect balance between size and performance. The stellar performance and asymmetrical design make this a perfect choice for musicians, entertainers and DJs when portability is key, or when hung by the suspension points, an exceptional light-duty installation speaker. For applications requiring full bandwidth sound reproduction, the PRX712 delivers the optimum balance. For live music, recorded music playback and speech the user has the option of tailoring the EQ, "Main" for for Front-Of-House application, or "Monitor" for deployment as a floor wedge. A dynamic microphone can be directly connected to the speaker input for quick PA applications. Coupled with a PRX700 sub-woofer, the system becomes an efficient, full-range sound system.
The PRX712 is comprised of a 12" Differential Drive® woofer, a 2408H-1 1.5" (37.5 mm) annular polymer diaphragm, neodymium compression driver mounted to a 90° x 50° horn, all driven by 1,500 watt Class-D power amplifier. A sophisticated DSP chip is at the core of a fully featured input section, providing user selectable system EQ, protection, input sensitivity selection, cross-over functionality, dynamic limiting and discrete component optimization.
All PRX700 cabinets are built from a combination of 25 mm (on the top and bottom for added rigidity) and 18 mm, strong, light-weight poplar plywood made structurally sound with tongue and groove joints. All PRX700 Series cabinets are protected by JBL's tour proven DuraFlex™ finish. Grilles are made from dent-resistant 16 gauge steel and handles are made from light-weight glass-filled nylon for added strength and durability. All M10 suspension points are constructed from 14 gauge steel and have been tested with a yield-strength of 1,000 lbs. each.
The amplifier input panel offers XLR, 1/4", and RCA jack compatibility, and a sensitivity switch provides extra flexibility, making it possible to connect literally any sound source without using a mixer. Signal and limiter lights indicate the system status and assist in setting the optimum level, via the level control knob.
Specifications: • System type: Self-powered 12", two-way, bass-reflex • Maximum SPL output: 135 dB peak • Frequency range (-10 dB): Main setting: 44.8 Hz – 19.6 kHz; Monitor setting: 44.8 Hz – 19.5 kHz • Frequency response (±3 dB): Main setting: 55.7 Hz – 18.2 kHz; Monitor setting: 56.5 Hz – 17.7 kHz • Coverage pattern: 90º x 50º nominal • Amp design: Class D • Power rating: 1,500 watts • Dimensions: 24.11" x 15.14" x 13.44" (612.4 x 384.56 x 341.38 mm) • Net weight: 42.5 lbs.
  • Speaker TypeActive / Powered
  • Woofer Size12"
  • BrandJBL Professional
  • ModelPRX712
  • Part Number245-8110
  • UPC050036904421
  • Weight50.0000 lbs.
View similar products to the JBL PRX712 12" 2-Way Powered PA Loudspeaker System
