JBL PRX625 Dual 15" 2-Way Active Powered PA Speaker 1500W
Brand:|Model: PRX625|Part # 245-852
The JBL PRX625 is comprised of two 15" 265F Differential Drive® woofers, a 2408H-1 1.5" annular polymer diaphragm, neodymium compression driver mounted to a 90° by 50° horn, all driven by a multi-channel Crown® Class-D power amplifier.
Part # 245-852
  • Maximum SPL output 135 dB peak
  • 15" (2 x 380 mm) Differential Drive® dual voice-coil and magnetic gap, neodymium woofers
  • 1.5" (37.5 mm) annular polymer diaphragm, neodymium compression driver
  • 1,500 Watt (3 x 500 watt) Class-D, Crown® digital amplifier
  • DSP input section with dbx® Type IV™ limiter circuit, crossover, dynamic limiting
  • Professional XLR line and 1/4" Mic/Instrument inputs, with loop through
  • Obsidian DuraFlex™ coated plywood construction
The JBL PRX625 is a self-powered, lightweight two-way loudspeaker system capable of delivering a very high level of performance over a broad bandwidth. The PRX600 Series represent an evolutionary step in the efficient use of amplifier power, rugged durability and enhanced versatility in a self-powered loudspeaker. Designed from the ground up to perform in the real world of sound reinforcement where challenging audio environments, high ambient noise levels and loud volumes are the norm, the PRX600 Series are built to last a lifetime using our reliable and trustworthy, tour-tested technology. Knowing you can rely on your system to deliver everything you need gives you the freedom to deliver your best. That's performance you can trust.
If a simple set-up is required and full bandwidth output at high levels is a must, then the PRX625 is most likely the optimum solution. With the same foot print as the PRX515M, the dual 15" woofer design creates enough low frequency content to serve most live music or music playback situations. When coupled with a PRX subwoofer (or multiple subwoofers) the system becomes a high volume sound reinforcement solution, perfect for regional tour companies and AV Rental companies looking for a scalable, easy to employ audio solution. We recommend using the PRX618S-XLF in conjunction with the PRX625 as the extended low frequency capabilities of the subwoofer compliment the frequency response of the PRX625.
For live music, recorded music playback and speech the user has the option of tailoring the EQ, 'flat' for speech intelligibility and 'boost' for enhanced bass and crisp highs in recorded music playback. A microphone can be directly connected to the speaker input for quick on-the-fly PA applications.
The PRX625 is a self-powered, lightweight two-way loudspeaker system capable of delivering a very high level of performance over a broad bandwidth. The PRX625 is comprised of two 15" 265F Differential Drive® woofers, a 2408H-1 1.5" annular polymer diaphragm, neodymium compression driver mounted to a 90° by 50° horn, all driven by a multi-channel Crown® Class-D power amplifier. A propriety DSP chip is at the core of a fully featured input section, providing user selectable system EQ, protection, input sensitivity selection, cross-over functionality, dynamic limiting and discrete component optimization.
The amplifier input panel offers XLR or 1/4" jack compatibility and a sensitivity switch provides extra flexibility, making it possible to connect literally any sound source without using a mixer. Signal present and overload lights indicate the system status and assist in setting the optimum level, via the level control knob.
All PRX600 cabinets are built from a combination of 25 mm (on the top and bottom for added rigidity) and 18 mm, strong, light-weight poplar plywood made structurally sound with tongue and groove joints. All PRX600 Series cabinets are protected by JBL's tour proven DuraFlex™ finish. Grilles are made from dent-resistant 16 gauge steel and handles are made from light-weight glass-filled nylon for added strength and durability. All M10 suspension points are constructed from 14 gauge steel and have been tested with a yield-strength of 1,000 lbs. each.
Specifications: • System type: Self-powered dual 15", two-way, bass reflex • Max SPL output: 139 dB peak • Frequency range (-10 dB): Flat 40 Hz - 19.5 kHz; Boost 39 Hz - 19.5 kHz • Frequency response (±3 dB): Flat 55 - 27.5 kHz; Boost 50 Hz - 18 kHz • Coverage pattern: 90­­­° x 50° nominal • Amp design: Crown Class D • Power rating: 1,500 watts (3 x 500) • Dimensions: 41.47" H x 16.71" W x 16.27" D • Weight: 60 lbs.
  • Speaker TypeActive / Powered
  • Woofer Size15"
  • BrandJBL Professional
  • ModelPRX625
  • Part Number245-852
  • UPC050036903769
  • Weight71 lbs.
View similar products to the JBL PRX625 Dual 15" 2-Way Active Powered PA Speaker 1500W
