Clearance Item
245-851_ALT_0
JBL PRX615M 15" 2-Way Powered PA/Active Stage Monitor Speaker 1000W
Brand:| Model: PRX615M
The 2-way 15" is the most recognizable form of portable PA loudspeakers and offers the perfect balance between size and performance. JBL's PRX615M truly is an exception; it's small, light weight, versatile, and powerful.
A restocked/refurbished, or Open Box unit of the product is available -- see it now
  • Maximum SPL output 135 dB peak
  • 15" (380 mm) Differential Drive® dual voice-coil and magnetic gap, neodymium woofer
  • 1.5" (37.5 mm) annular polymer diaphragm, neodymium magnet compression driver
  • 1,000 Watt (Dual 500 watt) Class-D, Crown® digital amplifier
  • DSP input section with dbx® Type IV™ limiter circuit, crossover, dynamic limiting
  • Professional XLR line and 1/4" Mic/Instrument inputs, with loop through
  • Integrated 36 mm dual-angle pole mount socket
245-851
Weight: 53 lbs.
Comparable Items In Stock:
The 2-way 15" is the most recognizable form of portable PA loudspeakers and offers the perfect balance between size and performance. JBL's PRX615M truly is an exception; it's small, light weight, versatile, and powerful. The PRX600 Series represent an evolutionary step in the efficient use of amplifier power, rugged durability and enhanced versatility in a self-powered loudspeaker. Designed from the ground up to perform in the real world of sound reinforcement where challenging audio environments, high ambient noise levels and loud volumes are the norm, the PRX600 Series are built to last a lifetime using our reliable and trustworthy, tour-tested technology. Knowing you can rely on your system to deliver everything you need gives you the freedom to deliver your best. That's performance you can trust.
The 2-way 15" offers the perfect balance between size and performance. The PRX615M truly is an exception; it's small, light weight, versatile and powerful. The performance and asymmetrical design make this a perfect choice for musicians, entertainers and DJ’s when portability is key, or when hung by the suspension points, an exceptional light-duty installation speaker. All PRX600 Series speakers were designed to excel in sound reinforcement where challenging audio environments and loud volumes are the norm. For applications requiring full bandwidth sound reproduction, the PRX615M delivers the optimum balance. For live music, recorded music playback and speech the user has the option of tailoring the EQ, ‘flat’ for speech intelligibility, and ‘boost’ for enhanced bass and crisp highs in recorded music playback. A microphone can be directly connected to the speaker input for quick PA applications. Coupled with a PRX600 sub-woofer the system becomes an efficient, full-range sound system.
The PRX615M is comprised of a 15" (380 mm) 265F Differential Drive® dual voice-coil and magnetic gap, neodymium woofer, a 2408H-1 1.5" (37.5 mm) annular polymer diaphragm, neodymium compression driver mounted to a 90° x 50° horn, all driven by 1,000 watt (dual 500 watt) Crown® Class-D power amplifier. A propriety DSP chip is at the core of a fully featured input section, providing user selectable system EQ, protection, input sensitivity selection, cross-over functionality, dynamic limiting and discrete component optimization.
All PRX600 cabinets are built from a combination of 25 mm (on the top and bottom for added rigidity) and 18 mm, strong, light-weight poplar plywood made structurally sound with tongue and groove joints. All PRX600 Series cabinets are protected by JBL's tour proven DuraFlex™ finish. Grilles are made from dent-resistant 16 gauge steel and handles are made from light-weight glass-filled nylon for added strength and durability. All M10 suspension points are constructed from 14 gauge steel and have been tested with a yield-strength of 1,000 lbs. each.
The amplifier input panel offers XLR or 1/4" jack compatibility and a sensitivity switch provides extra flexibility, making it possible to connect literally any sound source without using a mixer. Signal present and overload lights indicate the system status and assist in setting the optimum level, via the level control knob.
Specifications: • System type: Self-powered 15", two-way, bass-reflex • Maximum SPL output: Full range: 135 dB peak, Monitor: 134 dB peak • Frequency range (-10 dB): Full range: 45 Hz – 19 kHz, Monitor: 48 Hz – 20 kHz • Frequency response (±3 dB): Full range: 54 Hz – 18 kHz, Monitor: 60 Hz – 18 kHz • Coverage pattern: 90º x 50º nominal • Amp design: Crown® Class D • Power rating: 1,000 watts (2 x 500) • Dimensions: 26" H x 16.9" W x 16.3" D (660 x 429 x 414 mm) • Net weight: 43.5 lbs.
  • Speaker TypeActive / Powered
  • ConfigurationStage Monitor
  • Woofer Size15"
  • BrandJBL
  • ModelPRX615M
  • Part Number245-851
  • UPC050036903738
  • Weight53 lbs.
View similar products to the JBL PRX615M 15" 2-Way Powered PA/Active Stage Monitor Speaker 1000W
Customer projects that include: JBL PRX615M 15" 2-Way Powered PA/Active Stage Monitor Speaker 1000W
