JBL PRX612M 12" 2-Way Powered PA/Active Stage Monitor Speaker 1000W
Brand:|Model: PRX612M|Part # 245-850
The JBL PRX612M is the most compact and versatile speaker in the PRX600 Series. It has been designed to deliver maximum performance for its weight and size as both a stage monitor and a front of house main PA.
Part # 245-850
  • Maximum SPL 134 dB peak
  • Dual purpose enclosure for both front-of house and floor monitor applications
  • Eight M10 fly points for horizontal or vertical suspension. One M10 pull-back point
  • Optimized EQ for monitor or front-of-house applications
  • 12" (305 mm) Differential Drive® dual voice-coil and magnetic gap, neodymium woofer
  • 1.5" (37.5 mm) annular polymer diaphragm, neodymium, compression driver
  • 1,000 watt (Dual 500 watt) Class-D, Crown® amplifier
The JBL PRX612M is the most compact and versatile speaker in the PRX600 Series. It has been designed to deliver maximum performance for its weight and size as both a stage monitor and a front of house main PA. The PRX600 Series represent an evolutionary step in the efficient use of amplifier power, rugged durability and enhanced versatility in a self-powered loudspeaker. Designed from the ground up to perform in the real world of sound reinforcement where challenging audio environments, high ambient noise levels and loud volumes are the norm, the PRX600 Series are built to last a lifetime using our reliable and trustworthy, tour-tested technology. Knowing you can rely on your system to deliver everything you need gives you the freedom to deliver your best. That's performance you can trust.
Two user selectable EQ settings are provided to optimize the system for either application. With a dual socket pole mount the PRX612M is a perfect match with a PRX618S subwoofer, offering a high performance self-powered sub/sat system.
The PRX612M is comprised of a 12" (305 mm) 265F Differential Drive® woofer, a 2408H-1, 1.5" (37.5 mm) annular polymer diaphragm, neodymium compression driver mounted to a 90° x 50° horn, all driven by 1,000 watt (dual 500 watt) Crown® Class-D digital power amplifier. A propriety DSP chip is at the core of a fully featured input section, providing user selectable system EQ, protection, input sensitivity selection, cross-over functionality, dynamic limiting and discrete component optimization.
All PRX600 cabinets are built from a combination of 25 mm (on the top and bottom for added rigidity) and 18 mm, strong, light-weight poplar plywood made structurally sound with tongue and groove joints. All PRX600 Series cabinets are protected by JBL's tour proven DuraFlex™ finish. Grilles are made from dent-resistant 16 gauge steel and handles are made from light-weight glass-filled nylon for added strength and durability. All M10 suspension points are constructed from 14 gauge steel and have been tested with a yield-strength of 1,000 lbs. each.
The amplifier input panel offers XLR or 1/4" jack compatibility and a sensitivity switch provides extra flexibility, making it possible to connect literally any sound source without using a mixer. Signal present and limiter lights indicate the system status and assist in setting the optimum level, via the level control knob.
Specifications: • System type: Self-powered 12", two-way, bass-reflex • Maximum SPL output: Full range: 134 dB peak, Monitor: 133 dB peak • Frequency range (-10 dB): Full range: 50 Hz – 19.5 kHz, Monitor: 51 Hz – 19.5 kHz • Frequency response (±3 dB): Full range: 60 Hz – 17.5 kHz, Monitor: 61 Hz – 18.5 kHz • Coverage pattern: 90º x 50º nominal • Amp design: Crown® Class D • Power rating: 1,000 watts (2 x 500) • Dimensions: 23.3" H x 13.9" W x 13.4" D (592 x 353 x 340 mm) • Net weight: 34.5 lbs.
  • Speaker TypeActive / Powered
  • ConfigurationStage Monitor
  • Woofer Size12"
  • BrandJBL Professional
  • ModelPRX612M
  • Part Number245-850
  • UPC050036903721
  • Weight42.7 lbs.
View similar products to the JBL PRX612M 12" 2-Way Powered PA/Active Stage Monitor Speaker 1000W
