JBL PRX415M 15" 2-Way PA / Stage Monitor Speaker System
Brand:|Model: PRX415M|Part # 245-823
JBL's PRX400 Series is designed to provide the sensitivity, frequency response and power handling needed for almost any professional audio environment, while still being reasonably priced.
Ships in 7-10 Business Days
List Price$686.00
You Save20%
Part # 245-823
  • 128 dB Maximum SPL rating
  • 90° x 50° coverage for even and smooth response on and off axis
  • Dual-angle pole socket for applications requiring tripod mounting
  • Tough DuraFlex™ enclosure finish
  • SonicGuard™ protects the high frequency driver from excess power
The PRX400 Series are crafted to excel in a multitude of demanding audio environments. Perfect for live sound reinforcement, DJ’s, House of Worship, public address, or even suspended in a commercial environment like a school or nightclub.
The PRX415M can be used as mains or monitors, and with the addition of the PRX418 subwoofer, you’ll have a sub/sat system capable of generating 135 dB of full-range, high quality audio.
All PRX400 passive speakers are comprised of tour-tested JBL components and feature professional connectivity via Neutrik® Speakon combination connectors.  PRX400 cabinets are artfully constructed from an 18mm Birch/Poplar multi-laminate hardwood covered in highly resilient DuraFlex™ and feature rugged 16 gauge steel grilles. All full range models utilize twelve M10 suspension points for safe deployment in light duty installations
Like all JBL Professional products, the PRX400 Series speakers have survived JBL’s grueling 100 hour power test. We submit each component and each system in the PRX400 Series to 100 hours of continuous, high level input. Very few of our competitors survive such brutality, but this testing ensures that your JBL speaker will perform perfectly for a lifetime of long, loud nights. We also submit all of our speakers to a barrage of other unforgiving environmental and strength tests. By exposing them to harsh temperatures and humidity we can make certain they will function anywhere on the planet. We conduct pull tests on the suspension points, drop tests on the cabinets, and packaging crush tests in an effort to ensure that you can hit the stage with confidence and pride for many years to come.
Specifications: • Frequency range (-10 dB): 50 Hz – 19 kHz • Frequency response (+-3 dB): 66 Hz – 16 kHz • Coverage pattern: 90° x 50° nominal • System sensitivity: 98 dB SPL ([email protected]) • Power rating, Pink noise: 300W continuous, 600W program, 1200W peak • Rated maximum SPL: 128 dB SPL peak • Nominal impedance: 8 ohms • Dimensions: 25.6" x 16.9" x 18" • Net weight: 46 lbs.
  • Woofer Size15"
  • BrandJBL Professional
  • ModelPRX415M
  • Part Number245-823
  • UPC050036904049
  • Weight46 lbs.
View similar products to the JBL PRX415M 15" 2-Way PA / Stage Monitor Speaker System
