245-8128_ALT_0
245-8128_ALT_1
JBL MSC1 Studio Monitor System Controller with Room Mode Correction
Brand:|Model: MSC1|Part # 245-8128
The MSC1 gives you control of three sources on two sets of monitors, while correcting undesirable response conditions introduced by environmental variables. The result is a supremely accurate mix regardless of room resonances, so your job is easier, and your finished product is amazing, every time.
ORDER TODAY
Ships in 7-10 Business Days
List Price$375.00
You Save20%
$299.00
Part # 245-8128
  • Fully featured monitor system controller
  • RMC room calibration w/included measurement mic
  • MSC1 Control Center software included
  • A/B/C inputs, A/B monitor outputs
  • Subwoofer output w/level, crossover, and polarity control
The MSC1 Monitor System Controller includes essential "Monitor Strip" features found in large mixing consoles so you can take control of all monitoring functions from your place at the mix position. Since the acoustics of the room can play a big part in what you hear, the MSC1 includes JBL's highly acclaimed RMC Room Mode Correction technology to tune your monitor system to the room. The end result is a calibrated reference environment in which your speakers work in harmony with your room to take the guesswork out of mixing.
Unless your room was professionally designed, your workspace may suffer from the effect of Room Modes: low frequency resonance that causes even the most experienced mixers to misjudge bass in the mix. RMC Room Mode Correction technology in the MSC1 Monitor System Controller measures response at the mix position and automatically balances and tunes the system to tackle low frequency problems caused by room modes and interference with the room's boundaries. System calibration is accomplished using MSC1 Control Center Software, your computer, and the supplied calibration microphone. The software also provides fine-tuning control of monitor EQ, subwoofer level and crossover settings.
The MSC1 gives you the ability to monitor up to three stereo input sources, such as a mixing console, computer workstation, and personal MP3 or CD player while controlling the volume of the monitor system. The MSC1's primary speaker "A" outputs include monitor EQ and RMC to tune the monitors to the room. A subwoofer can be connected for use with the "A" speakers, and the sub has its own output level control, selectable crossover settings and RMC to perfectly blend with the "A" speakers. The "B" speaker outputs allow connection of a second set of monitor speakers. The MSC1 also has a headphone output with independent level control.
Specifications: • Inputs: 4 x 1/4" TRS balanced; 2 x RCA unbalanced • Outputs: 5 x 1/4" TRS balanced; stereo 1/4" headphone • S/N, Dynamic range: 110 dB typical, A-weighted, 20 Hz - 20 kHz • Frequency response: +0/-0.5 dB, 20 Hz - 20 kHz • THD+N: < 0.04% A/D/A, 20 Hz - 20 kHz • A/D, DA converters: 24 Bit • Internal processing: 48 Bit, 48 kHz • Maximum input level: +24 dBu • Maximum output before clipping: +17 dBu • Dimensions: 7.8" x 6.5" x 3.25" (198 x 165 x 83 mm).
Included accessories: • RMC calibration microphone • Computer interconnect cables • MSC1 Control Center software.
Minimum system requirements: • Mac: OSX 10.4.1,1 or later; Power PC or Intel 2 GHz processor (duo core recommended) • Windows: XP (SP2), Vista, Windows 7 32/64-bit; 1.6 GHz processor (Netbook Atom processor not supported) • Common requirements: 200 MB free hard drive space; 1 GB RAM; 1024 x 768 minimum monitor resolution; soundcard with accessible analog In/Out connectors (external audio interface optional); open USB port.
  • BrandJBL Professional
  • ModelMSC1
  • Part Number245-8128
  • UPC050036903653
  • Product CategoryMonitoring & Controllers
  • Weight4.3 lbs.
View similar products to the JBL MSC1 Studio Monitor System Controller with Room Mode Correction
in the Monitoring & Controllers product category.
