JBL LSR4326P/PAK 6" 2-Way Bi-Amplified Studio Monitor Pair
Brand:|Model: LSR4326P/PAK|Part # 245-846
The LSR4326P/PAK 2-way bi-amplified system is made up of two 6" studio monitors and LSR4300's Control Center Software. LSR4300 Series systems can be configured with up to eight main speakers in any desired mix of 6" and 8" models and two subwoofers.
Part # 245-846
  • Advanced Linear Spatial Reference design ensures flatter-off-axis response
  • RMC™ Room Mode Correction provides electronic control of room modes
  • Integrated bi-amplification with factory calibrated sensitivities
  • Silk dome transducer with Elliptical Oblate Spheroidal waveguide for precise pattern control
  • Magnetically shielded transducers minimize interference when in close proximity to video monitors
  • Reinforced enclosure and convenient mounting points for mounted installation
  • Integral handles facilitate ease of positioning
The LSR4326P/PAK 2-way bi-amplified system is made up of two 6" studio monitors and LSR4300's Control Center Software. Designed for any application from simple stereo mixing to complex surround production, LSR4300 Series systems can be configured with up to eight main speakers in any desired mix of 6" and 8" models and two subwoofers. Since the small studio may lack the space to position surround channels at the optimal physical distance from the mix position, the system is automatically aligned so the sound arriving at the mix position from all speakers is balanced regardless of each speaker's actual physical placement. LSR4300 Control Center Software is a useful system set-up utility that allows you to access the functions of your JBL LSR4300 speakers and subwoofers using a computer. Without leaving your mix position, LSR4300 Control Center Software gives you the ability to modify system settings, and also view multiple speaker parameters at once in an easy-to-understand, user-configurable graphic display.
Specifications: • Frequency response: ±1.5 dB, 55 Hz–20 kHz; -3 dB, 47 Hz–22 kHz; 10 dB, 39 Hz–32 kHz • SPL/1m (continuous/peak): 106 dB/112 dB • Transducers: 6.25" 436H / 1" 431 G; Self-shielded, Neodymium motor structures • Sensitivity +4 dBu, -10 dBV: 94 dB/1m • Amplification: 150W/70W • Digital processing: 24 Bit, 96 kHz • Analog inputs: XLR, 1/4" Balanced, +4 dBu, -10 dBV • Digital inputs: AES/EBU XLR, S/PDIF RCA • Data connections: Harman HiQnet™ Network, USB, RMC mic • Dimensions: 15.25" H x 9.3" W x 10.3" D (387 mm x 236 mm x 262 mm).
The LSR4300 enhances computer-based production by incorporating system-wide volume control, input source selection, individual speaker solo and user EQ. Harman HiQnet™ Network protocol enables centralized system-wide control from any speaker, wireless remote control and computer using LSR4300 Control Center Software.
LSR4300 Series Studio Monitors are designed for critical stereo and multi-channel audio production applications that require exceptional spectral accuracy and high SPL capability. Acknowledging that much of today's production is carried out in acoustically untreated rooms, the LSR4300 Series combines JBL's Linear Spatial Reference technology and automated RMC™ Room Mode Correction, an onboard system that automatically compensates for low frequency anomalies measured at the mix position.
  • Speaker TypeActive / Powered
  • Speaker Configuration2-Way
  • Woofer Size6"
  • BrandJBL Professional
  • ModelLSR4326P/PAK
  • Part Number245-846
  • UPC050036903035
  • Product CategoryStudio Monitors
  • Unit of MeasurePR
  • Weight73.45 lbs.
View similar products to the JBL LSR4326P/PAK 6" 2-Way Bi-Amplified Studio Monitor Pair
in the Studio Monitors product category.
