JBL JRX215 15" 2-Way PA Speaker System 1000 Watt
Brand:|Model: JRX215|Part # 245-8102
The JBL JRX215 trapezoidal, 15" speaker system is at home in live sound, dance music, and speech reinforcement.
List Price$374.00
You Save20%
$299.99
Part # 245-8102
  • Legendary JBL engineering and sound quality
  • Rugged and acoustically superior 3/4" MDF enclosure material
  • All woofers and compression drivers manufactured in California by JBL
  • Tough, non-resonant all-steel handles and 18 gauge steel front grill
  • SonicGuard™ circuitry protects crossovers and HF components
  • PT™ Waveguide provides well-controlled coverage and low distortion
The JRX215 is a portable, fifteen-inch, two-way speaker system designed specifically for applications in live music, music playback, and reinforcement of speech. With the smooth, natural sounding mid-range of the system, the JRX215 does a great job projecting live vocals, solos and speech. The extended lows and great top-end make it at home for music playback in DJ applications or anywhere live sound reinforcement is needed . Features include the dual-angle, 36 mm pole-mount socket as well as Neutrik® Speakon® and 1/4" input connectors. The JBL JRX215 delivers the performance and prestige JBL is known for at an affordable price point.
Components: JBL M115-8 12" woofer, JBL 2414H-C 1" exit compression driver mounted on Progressive Transition™ Waveguide.
Specifications: • Power handling: 250 watts RMS/1,000 watts peak • Recommended amplifier power: 250 watts to 500 watts • Frequency response (-10 dB): 41 Hz to 18 kHz • Nominal impedance: 8 ohms • Sensitivity: 99 dB 1W/1m • Maximum SPL: 129 dB • Nominal dispersion: 90° x 50° • Crossover frequency: 2.2 kHz • Input connectors: Neutrik Speakon® NL-4, 1/4" TS phone jack • Weight: 60.5 lbs. • Dimensions: 27.5" x 18.1" x 17".
Just one example of JBL's innovation is the PT™ Waveguide design. For decades, horn designers were faced with trade-offs between well controlled coverage, low distortion, and good frequency response. JBL developed proprietary algorithms which give their PT Waveguides the best performance in all three areas.
Hardware
The JRX200 Series doesn't scrimp on the hardware either. All the JRX models use tough, non-resonant all-steel handles with big, beefy bars. And the entire baffle (not just the woofer) is protected by an 18 gauge steel grill.
JBL Drivers
All woofers and compression drivers used in the JRX200 Series are manufactured in Northridge, California by JBL Professional.
Enclosure Construction
Competitive systems typically use particle board construction and rely entirely on glue to hold it together. For the JRX200 Series, JBL selected a more rugged and acoustically superior 3/4" MDF material for the enclosures. And to make sure they stay together, they constructed them with advanced adhesives and closely spaced mechanical fasteners. Not only are the cabinets rugged, but the denser enclosure walls are more rigid, delivering better low end as a result.
SonicGuard™
Feedback, dropped microphones, pushing the amps into clipping—all these things can quickly destroy even the best high-frequency drivers. That's why JBL JRX200 speakers include SonicGuard™ protection. SonicGuard circuitry absorbs excess energy without interrupting the performance. No circuit breakers to reset, no fuses to replace, and no "poly-switches" to degrade sound quality.
"Power Handling" and "Peak Power Handling" ratings are based on the average and peak power capacity of product samples subjected to a 100 hour power test using random noise with a 6 dB crest factor, in accordance with IEC standards.
  • Woofer Size15"
  • BrandJBL Professional
  • ModelJRX215
  • Part Number245-8102
  • UPC050036904506
    (1 Reviews)
  • Weight67 lbs.
View similar products to the JBL JRX215 15" 2-Way PA Speaker System 1000 Watt
