JBL JRX125 Dual 15" 2-Way PA Speaker System
Brand:|Model: JRX125|Part # 245-814
JBL's JRX125 is actually a "quasi three-way" design. This means that the upper woofer covers lows and mids but the bottom woofer uses a lower crossover frequency and covers only lows, acting as a built-in subwoofer.
Comparable Items In Stock:
Part # 245-814
  • Legendary JBL engineering and sound quality
  • Rugged and acoustically superior 3/4" MDF enclosure material
  • All woofers and compression drivers manufactured in California by JBL
  • Tough, non-resonant all-steel handles and 18 gauge steel front grill
  • SonicGuard™ circuitry protects crossovers and HF components
  • PT™ Waveguide provides well-controlled coverage and low distortion
Dual 15" speaker systems have become one of the most popular configurations with DJs and musicians who are looking for more low-frequency performance while maintaining the simplicity of a single-box system. JBL's JRX125 is actually a "quasi three-way" design. This means that the upper woofer covers lows and mids but the bottom woofer uses a lower crossover frequency and covers only lows, acting as a built-in subwoofer. You get the extra low-end of a dual 15" rig while maintaining the superior mid-frequency performance of a single driver system.
Components: JBL M115-8A 15" woofer (x2), JBL 2412 1" exit compression driver mounted on Progressive Transition™ Waveguide.
Specifications: • Power handling: 500 watts RMS/2,000 watts peak • Recommended amplifier power: 500 watts to 1,000 watts • Frequency response (-10 dB): 36 Hz to 16 kHz • Nominal impedance: 4 ohms • Sensitivity: 100 dB 1W/1m • Maximum SPL: 133 dB • Nominal dispersion: 90° x 50° • Crossover frequency: 2 kHz • Input connectors: Neutrik Speakon® NL-4, 1/4" TS phone jack • Weight: 94 lbs. • Dimensions: 43.25" x 18.25" x 17".
Just one example of JBL's innovation is the PT™ Waveguide design. For decades, horn designers were faced with trade-offs between well controlled coverage, low distortion, and good frequency response. JBL developed proprietary algorithms which give their PT Waveguides the best performance in all three areas.
Hardware
JRX100 doesn't scrimp on the hardware either. All the JRX models use tough, non-resonant all-steel handles with big, beefy bars. And the entire baffle (not just the woofer) is protected by an 18 gauge steel grill.
JBL Drivers
All woofers and compression drivers used in JRX100 are manufactured in Northridge, California by JBL Professional.
Enclosure Construction
Competitive systems typically use particle board construction and rely entirely on glue to hold it together. For JRX100, JBL selected a more rugged and acoustically superior 3/4" MDF material for the enclosures. And to make sure they stay together, they constructed them with advanced adhesives and closely spaced mechanical fasteners. Not only are the cabinets rugged, but the denser enclosure walls are more rigid, delivering better low end as a result.
SonicGuard™
Feedback, dropped microphones, pushing the amps into clipping—all these things can quickly destroy even the best high-frequency drivers. That's why JBL JRX100 speakers include SonicGuard™ protection. SonicGuard circuitry absorbs excess energy without interrupting the performance. No circuit breakers to reset, no fuses to replace, and no "poly-switches" to degrade sound quality.
"Power Capacity" and "Peak Power Capacity" ratings are based on the average and peak power capacity of product samples subjected to a 100 hour power test using random noise with a 6 dB crest factor, in accordance with IEC standards.
  • Woofer Size15"
  • BrandJBL Professional
  • ModelJRX125
  • Part Number245-814
  • UPC050036902786
    (2 Reviews)
  • Weight101 lbs.
View similar products to the JBL JRX125 Dual 15" 2-Way PA Speaker System
