JBL JRX118SP Powered 18" Compact Subwoofer System
Brand:|Model: JRX118SP|Part # 245-818
For those who prefer the simplicity of a self-powered subwoofer, there's the JBL JRX118SP. The JRX118SP features dual inputs with balanced XLR connectors and a peak limiter plus a built-in stereo crossover network facilitates use with JBL EON or other powered satellite speakers.
Part # 245-818
  • Legendary JBL engineering and sound quality
  • Peak limiter protects the amplifier and speaker from clipping
  • Rugged and acoustically superior 3/4" MDF enclosure material
  • All woofers manufactured in California by JBL
  • Tough, non-resonant all-steel handles and 18 gauge steel front grill
For those who prefer the simplicity of a self-powered subwoofer, there's the JRX118SP. JBL started with the same woofer used in the non-powered JRX118S and added a specially designed amplifier with 500 watts (peak) and 300 watts (continuous) power output. The JRX118SP features dual inputs with balanced XLR connectors and a peak limiter that protects the amplifier and speaker from clipping. A built-in stereo crossover network facilitates use with EON or other powered satellite speakers.
Specifications: • Frequency response(-10 dB): 38 to 300 Hz • Frequency response (± 3 dB): 55 Hz to 300 Hz • Amplifier power: 500 watts peak, 300 watts continuous, with <0.2% THD • Maximum SPL: 123 dB • Input connectors: XLR/M (line level, balanced), plus 1/4" TS phone jack (speaker level) • Output connectors: XLR/F (Selectable, Thru, or High Pass) • Components: JBL 2043G 18" woofer • Weight: 89 lbs. • Dimensions: 23.5" x 20.3" x 23.5".
JBL Drivers: All woofers and compression drivers used in JRX100 are manufactured in Northridge, California by JBL Professional.
Hardware: JRX100 doesn't scrimp on the hardware either. All the JRX models use tough, non-resonant all-steel handles with big, beefy bars. And the entire baffle (not just the woofer) is protected by an 18 gauge steel grill.
Enclosure Construction: Competitive systems typically use particle board.
  • Speaker TypeActive / Powered
  • ConfigurationSubwoofer
  • Woofer Size18"
  • BrandJBL Professional
  • ModelJRX118SP
  • Part Number245-818
  • UPC050036902809
  • Weight96.75 lbs.
View similar products to the JBL JRX118SP Powered 18" Compact Subwoofer System
