JBL EON515XT Powered 15" Portable Active PA Speaker System 625 Watt
Brand:|Model: EON515XT|Part # 245-293
JBL's EON515XT features a Crown® Class-D amplifier, one JBL 265F-1 15" Differential Drive® integrated woofer with dual 2” voice coils, and one JBL 2414H 1.5" (37.5 mm) annular polymer diaphragm, neodymium compression driver.
Comparable Items In Stock:
Part # 245-293
  • Highly designed composite enclosures for durability, lightweight, and precise acoustic performance
  • True portability weighing only 32.5 lbs. (14.8 kg)
  • Multiple handles with comfort rubber grips for easy transport
  • Multi angle enclosure for main PA or floor monitor applications
  • Integrated M10 suspension points for easy fixed installation
  • 100º H x 60º V asymmetrical wave guide for uniform audience coverage
  • 15” Differential Drive® low-frequency driver with neodymium magnet for low-distortion and light weight
JBL's EON515XT features a Crown® Class-D amplifier, one JBL 265F-1 15" Differential Drive® integrated woofer with dual 2” voice coils, and one JBL 2414H 1.5" (37.5 mm) annular polymer diaphragm, neodymium compression driver in a multi angle enclosure for main PA or floor monitor applications. The EON 515XT was engineered for durability, high performance and ease of use. We’ve extended the reach of the current EON technology by improving input sensitivity, lowering the noise floor, adding user selectable EQ control and re-voicing the system for peak performance and enhanced audio precision. The intuitive onboard 3-channel mixer with adjustable EQ assures that you’re in control of the sound and the sturdy construction and superior ergonomic design will guarantee a lifetime of reliability and simplicity. Integrated M10 suspension points for easy fixed installation. Has an integrated 36 mm pole mount socket with stabilizing securing screw. Multiple handles with comfort rubber grips allow for easy transport. Features easy “Daisy-Chain” connections for extending the system.
Specifications: • System power rating: 625 watts (525 + 100) • Frequency range (-10 dB): 39 Hz -20 kHz • System type: Self powered 15", two-way, bass-reflex • Maximum SPL output: 132 dB • Frequency response (±3 dB): 42 Hz - 18 kHz • Input connectors: 2 x 1/4” TRS phone jacks balanced/unbalanced 1 x XLR / 1/4" TRS combo jack with XLR loop through • Input impedance: 14k ohms • Signal indicators: Limit, signal, mic, EQ, bass, and treble • Mic input gain: -Infinity to +40 dBu • Line input gain: -Infinity to +4 dBu (+18 dBu maximum input level) • Limiter: Yes •  Amplifier design: Crown® Class-D • LF Driver: One x JBL 265F-1 15" (380 mm) Differential Drive® integrated woofer with dual 2” voice coils • HF Driver: One x JBL 2414H 1.5" (37.5 mm) annular polymer diaphragm, neodymium compression driver • Coverage pattern: 100º H x 60º V nominal • Crossover frequency: 1.7 kHz • Material: Polypropylene, multi-purpose main & monitor • Suspension/Mounting: 36 mm pole socket with stabilizing screw, 5 x M10 suspension points • Handles: One left/right side, one on top, with rubber grip • Finish: Black granite • Grille: Powder coated perforated steel with acoustically transparent cloth backing • Dimensions: 26.5” H x 16” W x 14.5” D (673 x 406 x 368 mm) • Weight: 32.5 lbs. (14.8 kg).
  • Speaker TypeActive / Powered
  • Woofer Size15"
  • BrandJBL Professional
  • ModelEON515XT
  • Part Number245-293
  • UPC050036903820
    (2 Reviews)
  • Weight42.85 lbs.
View similar products to the JBL EON515XT Powered 15" Portable Active PA Speaker System 625 Watt
