JBL EON510 Powered 10" Portable Active PA Speaker System 280 Watt
Brand:|Model: EON510|Part # 245-290
The EON510 is a 10" two-way, powered, portable speaker system. Capable of reproducing full bandwidth sound at high levels it offers the additional utility of a 3 channel built-in mixer.
Comparable Items In Stock:
Part # 245-290
  • 280 watt High-Performance Powered Speaker System
  • Ultra light weight and extremely compact
  • Soft touch top grip for easy handling
  • 10" Differential Drive® LF driver with neodymium magnet for low-distortion and light weight
  • 1" throat diameter next generation JBL neodymium compression driver
  • Efficient Class-D digital amplifier technology
  • Built-in 3 Channel Mixer
The EON510 is a 10" two-way, powered, portable speaker system. Capable of reproducing full bandwidth sound at high levels it offers the additional utility of a 3 channel built-in mixer. The EON510 is comprised of a 254 mm (10") Differential Drive® woofer, a 25.4 mm (1") neodymium high frequency compression driver coupled to a 100° H by 60° V waveguide. Both components are driven by the discrete channels of a 280 watt Class-D integrated power amplifier. The input section contains all crossover functions, protection, and mixer functionality.
Applications: • Live sound reinforcement, speech and vocals, music playback in entertainment, A/V, and institutional venues – especially when ease of use and portability are important factors • Amplification, mixing, and monitoring for electronic musical instruments • Everywhere you need to be heard.
Specifications: • System power rating: 280W continuous, 560W peak • Frequency range (-10 dB): 58 Hz-18.5 kHz (EQ in 'Flat' position) • Frequency response (±3 dB): 70 Hz-17 kHz (EQ in 'Flat' position) • Coverage Pattern: 100° H x 60° V nominal • Maximum SPL: 121 dB • Dimensions (H x W x D): 490 x 313 x 262 mm (19.3" x 12.3" x 10.3") • Net weight: 7.7 kg (17 lbs.)
  • Speaker TypeActive / Powered
  • Woofer Size10"
  • BrandJBL Professional
  • ModelEON510
  • Part Number245-290
  • UPC050036903585
  • Weight25.55 lbs.
View similar products to the JBL EON510 Powered 10" Portable Active PA Speaker System 280 Watt
