JBL EON315 Powered 15" Portable Active PA Speaker System 280 Watt
Brand:|Model: EON315|Part # 245-295
The EON315 is a 15", two-way, powered, portable speaker system. It is a complete self contained sound reinforcement system, capable of full-bandwidth reproduction at high levels with the added benefit of a microphone pre-amp enabling the direct connection of a dynamic microphone.
Part # 245-295
  • 280 watt powered speaker system
  • Light weight—true portability weighing only 15.9 kg (35 lbs.)
  • Multiple handles for easy transport
  • 15" JBL low-frequency driver
  • 1" throat diameter next generation JBL neodymium compression driver
  • Efficient Class-D digital amplifier technology
  • 100° H x 60° V asymmetrical wave guide for uniform audience coverage
The EON315 is a 15", two-way, powered, portable speaker system. It is a complete self contained sound reinforcement system, capable of full-bandwidth reproduction at high levels with the added benefit of a microphone pre-amp enabling the direct connection of a dynamic microphone. The EON315 is comprised of a 380 mm (15") JBL woofer, a 25.4 mm (1") neodymium high frequency compression driver coupled to a 100° H by 60° V waveguide. Both components are driven by the discrete channels of a 280 watt Class-D integrated power amplifier. The input section contains all cross-over functions, protection, and system EQ functionality.
Specifications: • System power rating: 280W continuous, 560W peak • Frequency range (-10 dB): 38 Hz-20 kHz (EQ in 'Flat' position) • Frequency response (±3 dB): 50 Hz-18 kHz (EQ in 'Flat' position) • Coverage Pattern: 100° H x 60° V nominal • Maximum SPL: 127 dB • Dimensions (H x W x D): 685 x 438 x 366 mm (27" x 17.3" x 14.4") • Net weight: 15.9 kg (35 lbs.)
Applications: • Live sound reinforcement, speech and vocals, music playback in entertainment, A/V, and institutional venues – especially when ease of use and portability are important factors • Amplification and monitoring for electronic musical instruments • Everywhere you need to be heard.
  • Speaker TypeActive / Powered
  • Woofer Size15"
  • BrandJBL Professional
  • ModelEON315
  • Part Number245-295
  • UPC050036903592
  • Weight50.35 lbs.
View similar products to the JBL EON315 Powered 15" Portable Active PA Speaker System 280 Watt
