JBL Control 30-WH Indoor/Outdoor 3-Way Monitor System White
Brand:|Model: Control 30-WH|Part # 246-752
The JBL Control 30 3-way speaker system uses high power components and a complex network to achieve smooth high fidelity performance, extended bandwidth, and well-controlled, defined coverage from a compact loudspeaker.
ORDER TODAY
Ships in 7-10 Business Days
List Price$857.85
You Save20%
$686.00
Part # 246-752
  • Extremely smooth, flat frequency response with extended bandwidth
  • 120° x 110° HF coverage horn
  • 150 watt transformer for 70V or 100V lines, with 4 ohm bypass
  • SonicGuard™ overload protection
  • Simple and effective mounting solutions
The JBL Control 30 3-way speaker system uses high power components, computer optimized horn and coaxial component design, patent-pending cabinet manufacturing techniques, and a complex network to achieve smooth high fidelity performance, extended bandwidth, and well-controlled, defined coverage from a compact loudspeaker. Components: 10" fiberglass/Kevlar™ cone LF woofer, neodymium magnet coaxial 5" anodized aluminum cone MR, and 1" titanium diaphragm HF compression driver.
Specifications: • Frequency response: 38 Hz to 17 kHz (-10 dB) • Power handling: 500 watts continuous program power (250W pink noise) • Sensitivity: 93 dB (1W/1m) • Transformer taps: 150W, 75W, 38W at 70V/100V (plus 19W tap at 70V only) • Nominal impedance: 4 ohms (bypass) • Dimensions: 23.3" x 14.6" x 13.5".
  • Input Rating70V,100V,4 ohm
  • Special FeaturesIndoor / Outdoor
  • Woofer Diameter10"
  • Configuration3-way
  • ColorWhite
  • BrandJBL Professional
  • ModelControl 30-WH
  • Part Number246-752
  • UPC844632066344
  • Weight54.25 lbs.
View similar products to the JBL Control 30-WH Indoor/Outdoor 3-Way Monitor System White
