JBL Control 25AV 5-1/4" 2-Way Shielded Speaker Pair Black
Brand:|Model: Control 25AV|Part # 246-730
Control 25AV Contractor Series surface-mount video-shielded speakers are loaded with complication-reducing innovations. Rugged molded high-impact polystyrene (HIPS) enclosures balance mass, strength, and resonance, perfectly complementing their respective transducers.
Comparable Items In Stock:
Part # 246-730
  • Video shielded for use near video monitors
  • 100° x 100° nominal dispersion
  • 8 ohms bypass setting
  • High-Impact Polystyrene (HIPS) enclosure
  • Stainless steel grill for harsh environments
  • Zinc-plated screw down input terminal strip
Control 25AV Contractor Series surface-mount video-shielded speakers are loaded with complication-reducing innovations. Rugged molded high-impact polystyrene (HIPS) enclosures balance mass, strength, and resonance, perfectly complementing their respective transducers. The symmetrical horn geometry delivers precise directability and control. Compact design dimensions and textured, ready-to-paint exterior surfaces make the Control Contractor Series unobtrusive in any decor. JBL's Invisiball™ mounting system (patent pending), innovative bracketing solutions, zinc-plated screw down input terminal strip, and factory-installed autoformers take the headaches out of installation. Extensive use of high-tech materials adds years to speaker life expectancy while increasing weather resistance. Components: 5-1/4" polypropylene coated woofer, 3/4" titanium coated horn-loaded tweeter.
Specifications: • Frequency response: 70 Hz to 23 kHz (-10 dB) • Power handling: 200 watts continuous program power (100W pink noise) • Sensitivity: 87 dB (1W/1m) • Crossover frequency: 3 kHz • Transformer taps: 60W, 30W, 15W, 7.5W at 70V, 60W, 30W, 15W, at 100V • Nominal impedance: 8 ohms (bypass) • Dimensions: 9.3" x 7.4" x 5.8".
  • Input Rating8 ohm,70V,100V
  • Special FeaturesIndoor / Outdoor,Water Resistant
  • Woofer Diameter5-1/4"
  • Configuration2-way
  • ColorBlack
  • BrandJBL Professional
  • ModelControl 25AV
  • Part Number246-730
  • UPC844632066238
  • Product CategoryMulti-purpose On-wall Speakers
  • Unit of MeasurePR
  • Weight10 lbs.
View similar products to the JBL Control 25AV 5-1/4" 2-Way Shielded Speaker Pair Black
in the Multi-purpose On-wall Speakers product category.
