JBL Control 24CT Micro 4" 2-Way Ceiling Speaker Pair
Brand:|Model: Control 24CT Micro|Part # 246-702
Low distortion and a smooth, natural frequency response make the Control 24CT Micro ideal for medium-volume business music systems as well as for the medium to low SPL segments of larger or louder systems.
- Order Soon - Only 3 Left In Stock
List Price$184.00
You Save22%
$144.00
Part # 246-702
  • Extremely wide 150° coverage
  • Smooth frequency response
  • 4-1/2" woofer, injection molded graphite cone with butyl rubber surround
  • 1/2" polycarbonate tweeter for extended response
  • 8 watt multitap transformer for 70V/100V systems
  • Shallow 4" depth
  • Packaged with grill, backcan and tile rails for fast installation and easy dealer stocking
The Control 24CT Micro is a compact in-ceiling speaker, providing full, high quality sound for background music and music-plus-paging systems. These speakers are ideally suited for a wide variety of applications, from restaurants and specialty retail stores to professional offices and airports. Low distortion and a smooth, natural frequency response make the Control 24CT Micro ideal for medium volume business music systems as well as for the medium to low SPL segments of larger or louder systems. Low frequency output can be augmented with the addition of one of the Control Contractor subwoofer models. Similar mid/high frequency voicing to other JBL Control Contractor loudspeakers can, in many systems, allow for mixing and matching of models within zones without requiring separate equalization.
Installation of the Control 24CT Micro is quick and easy. The loudspeaker is packaged with the backcan, grill, support backing bracket and tile rails. In addition, optional new
construction brackets are available. The entire installation can be accomplished without requiring access above the ceiling. A template is provided for marking the cutout. An innovative C-shaped support backing plate can be installed from below through the cutout to reinforce the top of the ceiling material. Tile bridge rails are included which can be screwed onto the C-plate to extend support to the T-channel grid in suspended ceiling installations. After the speaker is fitted through the cutout, it is held securely in place via mounting tabs which tighten onto the C-plate, if used, or directly onto the ceiling material. The Control 24CT Micro backcan is made of formed steel and the speaker is suitable for use in air handling spaces per UL2043. An attachment loop is provided on the backcan for cabling. A seismic tab is provided as a secondary support.
The Control 24CT Micro trim and baffle are paintable to match any decor.
Specifications: • Frequency response: 85 Hz to 20 kHz (-10 dB) • Power handling: 30 watts continuous program power (15 watts pink noise) • Sensitivity: 86 dB (1W/1m) • 70V/100V taps: 8W, 4W, 2W, 1W (and 0.5W for 70V only) • Dimensions: 4.2" H x 7.7" Dia. • Weight: 4.4 lbs.
  • Input Rating70V,100V
  • Mounting StyleIn-ceiling
  • Special FeaturesEnclosed Back,UL1480,UL2043
  • Woofer Diameter4"
  • BrandJBL Professional
  • ModelControl 24CT Micro
  • Part Number246-702
  • UPC844632066092
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
  • Unit of MeasurePR
    (1 Reviews)
  • Weight4.85 lbs.
View similar products to the JBL Control 24CT Micro 4" 2-Way Ceiling Speaker Pair
in the In-Ceiling / On-Ceiling Speakers product category.
