JBL 2241H 18" High-Power LF Driver
Brand:|Model: 2241H|Part # 294-460
The 2241H 18" low frequency transducer represents the results of JBL's latest engineering research in professional high power transducer design. Great for portable subwoofer rigs or fixed installs.
Ships in 7-10 Business Days
Part # 294-460
The 2241H 18" low frequency transducer represents the results of JBL's latest engineering research in high power transducer design. For increased power handling while reducing power compression, a unique direct voice coil-to-air heat dissipation method called Vented Gap Cooling has been used. This process pumps air through the magnetic gap and directly over and around the voice coil to provide immediate heat transfer and reduction in operating temperature. Through the use of new computer-aided magnet optimization and analysis techniques comes a new weight-optimized Symmetrical Field Geometry (SFG) magnet structure, resulting in a reduction of overall driver weight and a significant reduction in harmonic distortion. This new magnet structure offers much of the weight advantage of rare earth magnet structures without their prohibitive cost.
  • Nominal Diameter18"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance8 ohms
  • Frequency Response30 to 3,000 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)2.5 ohms
  • Voice Coil Inductance (Le)0.86 mH
  • Mechanical Q (Qms)5.7
  • Electromagnetic Q (Qes)0.43
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)11 ft.³
  • Maximum Linear Excursion (Xmax)7.6 mm
  • Surface Area of Cone (Sd)1241.29 cm²
  • Cone MaterialPaper
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.25"
  • Baffle Cutout Diameter16.75"
  • Depth7"
  • # Mounting Holes8
  • Sealed Volume2.81 ft.³
  • Sealed F375 Hz
  • Vented Volume8.41 ft.³
  • Vented F343 Hz
  • BrandJBL Professional
  • Model2241H
  • Part Number294-460
  • UPC844632005763
    (4 Reviews)
  • Weight23.5 lbs.
View similar products to the JBL 2241H 18" High-Power LF Driver
