JBL 2226J 15" High-Power LF Driver 16 Ohm
Brand:|Model: 2226J|Part # 294-472
The 2226J 15" low frequency transducer represents the results of JBL's latest engineering research in high power transducer design.
ORDER TODAY
Ships in 7-10 Business Days
$503.00
Part # 294-472
The 2226J 15" low frequency transducer represents the results of JBL's latest engineering research in high power transducer design. For increased power handling while reducing power compression, a unique direct voice coil-to-air heat dissipation method called Vented Gap Cooling has been used. This process pumps air through the magnetic gap and directly over and around the voice coil to provide immediate heat transfer and reduction in operating temperature. Through the use of new computer-aided magnet optimization and analysis techniques comes a new weight-optimized Symmetrical Field Geometry (SFG) magnet structure, resulting in a reduction of overall driver weight and a significant reduction in harmonic distortion. This new magnet structure offers much of the weight advantage of rare earth magnet structures without their prohibitive cost.
  • Nominal Diameter15"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance16 ohms
  • Frequency Response30 to 2,500 Hz
  • Sensitivity97 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)40 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.75 mH
  • Mechanical Q (Qms)5
  • Electromagnetic Q (Qes)0.33
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)6.2 ft.³
  • Maximum Linear Excursion (Xmax)7.6 mm
  • Surface Area of Cone (Sd)883.87 cm²
  • Cone MaterialPaper / Glass Fiber
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.25"
  • Baffle Cutout Diameter14"
  • Depth5.5"
  • # Mounting Holes8
  • Sealed Volume0.87 ft.³
  • Sealed F3110 Hz
  • Vented Volume2.03 ft.³
  • Vented F369 Hz
  • BrandJBL Professional
  • Model2226J
  • Part Number294-472
  • UPC844632066948
  • Weight23.3 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the JBL 2226J 15" High-Power LF Driver 16 Ohm
