JBL 2226H 15" High-Power LF Driver 8 Ohm
Brand:|Model: 2226H|Part # 294-470
The 2226H 15" low frequency transducer represents the results of JBL's latest engineering research in professional high power transducer design. Great for portable subwoofer rigs or fixed installs.
$503.00
Part # 294-470
The 2226H 15" low frequency transducer represents the results of JBL's latest engineering research in high power transducer design. For increased power handling while reducing power compression, a unique direct voice coil-to-air heat dissipation method called Vented Gap Cooling has been used. This process pumps air through the magnetic gap and directly over and around the voice coil to provide immediate heat transfer and reduction in operating temperature. Through the use of new computer-aided magnet optimization and analysis techniques comes a new weight-optimized Symmetrical Field Geometry (SFG) magnet structure, resulting in a reduction of overall driver weight and a significant reduction in harmonic distortion. This new magnet structure offers much of the weight advantage of rare earth magnet structures without their prohibitive cost.
  • Nominal Diameter15"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance8 ohms
  • Frequency Response30 to 2,500 Hz
  • Sensitivity97 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)40 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.75 mH
  • Mechanical Q (Qms)5
  • Electromagnetic Q (Qes)0.33
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)6.2 ft.³
  • Maximum Linear Excursion (Xmax)7.6 mm
  • Surface Area of Cone (Sd)883.87 cm²
  • Cone MaterialPaper / Glass Fiber
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.25"
  • Baffle Cutout Diameter14"
  • Depth5.5"
  • # Mounting Holes8
  • Sealed Volume0.87 ft.³
  • Sealed F3110 Hz
  • Vented Volume2.03 ft.³
  • Vented F369 Hz
  • BrandJBL Professional
  • Model2226H
  • Part Number294-470
  • UPC844632005770
    (6 Reviews)
  • Weight19.3 lbs.
