Jantzen 0622 0.56uF 800V Z-Silver Capacitor
Jantzen Audio 0.56uF 800V Z-Silver Capacitor
Brand:|Model: 001-0622|Part # 027-760
Jantzen Audio Silver capacitors are possibly the most detailed caps on the market. These caps are constructed of a specially wound metallized polypropylene, high purity silver leads for the absolute best signal transfer, resin-sealed end caps to protect against humidity, and flame-retardant tape wrap.
  • Silver leads
  • 800 VDC
  • High current capacity
  • 2% tolerance
  • Dimensions: 16 mm x 43 mm
Jantzen Audio Silver capacitors are possibly the most detailed caps on the market. These caps are constructed of a specially wound metallized polypropylene to minimize inner vibration, which keeps microphonic effects as low as possible. Silver Series caps also feature high purity silver leads for the absolute best signal transfer, resin-sealed end caps to protect against humidity, and flame-retardant tape wrap. The result is a reliable and consistent product that facilitates the construction of high quality, precision crossovers. Silver Series caps are natural sounding without audible coloration of the audio signal, delivering an authentic soundstage and neutral tonal balance. Sonically, they behave more like a fine piece of wire than a capacitor. Truly, an outstanding audio component! Jantzen Audio p/n 001-0622.
Specifications: • Rated: <0.33 uF @ 800 VDC, >0.47 uF @ 1200 VDC • Tolerance: 2% • Value: 0.56 uF • Dimensions: 20 mm Dia. x 39 mm L.
  • Capacitance0.56 µF
  • Voltage Rating800V
  • Tolerance2%
  • BrandJantzen Audio
  • Model001-0622
  • Part Number027-760
  • UPC844632062131
  • Product CategoryMetalized Polypropylene Crossover Capacitors
  • Weight0.02 lbs.
