Jantzen 1913 3.0mH 20 AWG Air Core Inductor
Jantzen 3.0mH 20 AWG Air Core Inductor Crossover Coil
+/-3% tolerance, high-purity copper, and baked perfect layer air core construction virtually eliminates hysteresis, FM, and saturation distortions. 200 watts RMS.
255-056
Weight: 0.41 lbs.
IN STOCK
List Price$15.66
You Save24%
$11.78
Buy 4-up$10.73
Part # 255-056
Jantzen 20 gauge air core inductors share the same quality and construction as their 18 gauge counterparts, including ±3% tolerance, high-purity copper, and tie-free design. Baked perfect layer air core construction virtually eliminates hysteresis, FM, and saturation distortions.
Specifications: • Inductance: 3.00 mH • Wire gauge: 20 AWG • DC resistance: 1.38 Ohms • Dimensions: 1.73" x 1.18" • Power handling: 200 watts RMS.
  • Inductance3 mH
  • Wire Gauge20 AWG
  • Inductor TypeAir Core
  • BrandJantzen Audio
  • Part Number255-056
  • UPC844632024641
  • Product CategoryAir Core Inductor Crossover Coils
    (5 Reviews)
  • Weight0.41 lbs.
View similar products to the Jantzen 3.0mH 20 AWG Air Core Inductor Crossover Coil
in the Air Core Inductor Crossover Coils product category.
Jantzen 3.0mH 20 AWG Air Core Inductor Crossover Coil is rated 4.8 out of 5 by 5.
Rated 5 out of 5 by from GoodNo complaints. Just keep in mind that the resistance is a bit high.
Date published: 2013-06-18
Rated 5 out of 5 by from surprisedFor what these cost I was very surprised to find neat clean tight windings and very acceptable lead length. For the money these really were a bargain compaired to some of the budget on a bobbin air coils I have used in the past. Easy to unwind a few turns to get to the exact value needed and make matched pairs, sound and look great... can you ask for much more?
Date published: 2012-02-28
Rated 5 out of 5 by from Great Product~Functions As Advertised!!!!Used this inductor in the band pass section of a 3-way design using Dayton's 2" Reference Mid Range Dome. Inductor does its job nicely!!!
Date published: 2008-08-24
Rated 5 out of 5 by from You Can Hear The DifferenceTo get more for my money, I converted my wife's entertainment center into a pair of massive enclosures. But when I put the bulk of my budget into woofers, I had to settle for cheap generic crossovers. Promising I'd do better when I could, I purchased a pair of Jantzen 20s and was blown away by the difference. On its Crossover page, Parts Express has crossover chart and a schematic for both first- and second-order crossovers. I followed the instructions and attached my coils directly to the woofers. Along with the matching capacitors, I was able to make inexpensive crossovers for my woofers and it really brought out the definition in my bass. Between the coils and the caps, I probably spent $34, but the results were like night and day.
Date published: 2008-08-17
Rated 4 out of 5 by from Excellent manufacturingI wish the label they put on the outside was affixed a little better. It has a tendency to come off with the protective wrapping put on for shipment.
Date published: 2008-02-10
DIMENTIONS: Hight and witdth are not specified. Measurements are given, which one is the hight?
Asked by: c.hartjr
The Jantzen 3.0mH 20 AWG Air Core Inductor dimensions are 1.73" height and 1.18 " diameter or (width) . The inductor has a 200 watt handling capacity and is an excellant choice for your crossover.Good Luck
Answered by: Nitnub
Date published: 2011-10-26
Customer projects that include: Jantzen 3.0mH 20 AWG Air Core Inductor Crossover Coil
