Jantzen 0272 22uF 400V Crosscap Capacitor
Jantzen 22uF 400V Crosscap Capacitor
Jantzen CrossCaps are built from ultra-high-quality Finnish metallized film and provide superb sonic accuracy and detail for any audio application. 400 VDC rating is excellent for crossover networks, allowing the capacitors to flawlessly handle large current peaks without distortion.
  • 400 VDC
  • 5% Tolerance
  • Tinned pure copper leads
  • 32 mm Dia. x 44 mm L.
  • Metallized polypropylene construction
027-940
Weight: 0.01 lbs.
IN STOCK
List Price$11.50
You Save24%
$8.65
Buy 4-up$7.76
Part # 027-940
Jantzen CrossCaps are built from ultra-high-quality Finnish metallized film and provide superb sonic accuracy and detail for any audio application. Their outstanding electrical properties and 5% tolerance deliver the consistency and long-term reliability that you would expect from a premium polypropylene capacitor. 400 VDC rating is excellent for crossover networks, allowing the capacitors to flawlessly handle large current peaks without distortion. Also great for circuit or line-level applications.
Specifications: • Rated: 400 VDC • Tolerance: 5% • Value: 22.0 uF • Dimensions: 32 mm Dia. x 44 mm L.
  • Capacitance22 µF
  • Voltage Rating400V
  • Tolerance5%
  • BrandJantzen Audio
  • Part Number027-940
  • UPC844632002663
  • Product CategoryMetalized Polypropylene Capacitors
    (4 Reviews)
  • Weight0.01 lbs.
View similar products to the Jantzen 22uF 400V Crosscap Capacitor
in the Metalized Polypropylene Capacitors product category.
Jantzen 22uF 400V Crosscap Capacitor is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from ExcellentI bought these to re-cap the crossovers in my Realistic Mach I's. They made my 30+ year old speakers sound new again.
Date published: 2011-02-17
Rated 5 out of 5 by from GreatBuilt these speakers to use with a 16 watt per channel tube amp.Used the 290-366 - Goldwood GW-1244 12" Butyl Surround Woofer 4 Ohmand 279-177 - Vifa BC25SG19-04 1" Textile Dome Shielded Tweeter 4 Ohm,Used a simple 6db crossover, a 027-940 - Jantzen 22uF 400V Crosscap Capacitor, with The 255-220 Jantzen 0.33mH 18 AWG Air Core Inductor. Constructed the two speaker boxes out of one sheet of plywood. The boxes are roughly 24 x 16 x 16 .Great sound for the price, a little bright, but with a low end below 40Hz. Would not hesitate to use the select components in another low power speaker project.
Rated 4 out of 5 by from check your size requirementsMy own mistake, this capacitor had a larger foot print than I expected.
Rated 4 out of 5 by from Good ValueThese caps are a good value and perform well. They also have some values that other companies do not offer.
Comma vs. Decimal in Printed Values
I'm not familiar with European Caps. I just received these caps and wanted to make sure that it's okay that they are marked, 22,00uF. I did read somewhere to just pretend the comma is a decimal, is that correct? I also received the same branded caps marked, 4,70uF.Thank You,Dex
Asked by: DexMan
The comma is indeed the proper decimal indicator and is used in most, if not all of Europe and other countries. I was raised in Germany and went through the entire school system there.I actually cringe at many of the extremely odd and unwieldy notations in use here in the USA, especially the division system that looks like a root symbol and is used nowhere else on the planet.
Answered by: lapratho
Date published: 2012-03-26
Customer projects that include: Jantzen 22uF 400V Crosscap Capacitor
