JamStands JS-MCTB200 Tripod Mic Stand w/Telescoping Boom
Brand:|Model: JS-MCTB200|Part # 242-743
Tripod mic stand with telescoping boom has a reliable tightening knob and a traditional turn clutch with an adjustable height of 39.25" to 69.25". Adjustable boom length: 20.75"-35.75".
List Price$69.99
You Save53%
$32.99
Part # 242-743
  • Heavy-duty performance stand for everyday use
  • Adjustable boom with reliable tightening knob
  • Strong, die-cast boom and leg housings
  • Scratch-resistant, powder-coated finish
  • Easily adjust stand height with traditional turn clutch
  • Three-year manufacturer's warranty
Tripod mic stand with telescoping boom has a reliable tightening knob and a traditional turn clutch with an adjustable height of 39.25" to 69.25" (1000-1760 mm). Heavy-duty performance stand for everyday use. A scratch-resistant powder coated finish with die-cast boom and leg housings. Adjustable boom length of 20.75" to 35.75". Model JS-MCTB200. Three-year manufacturer's warranty.
JamStands by Ultimate Support is a rugged new category of music products and accessories for the budget conscious musician. Whether a beginner, hobbyist, or pro, you'll find that their industry leading design team has developed the perfect accessory for your needs. Their wide range of choices include guitar, bass, amp, keyboard, DJ, live sound, benches, and sheet music stands all offered by Ultimate Support Systems – a brand you've known and trusted for over 30 years!
  • BrandJamStands
  • ModelJS-MCTB200
  • Part Number242-743
  • UPC784887167925
  • Product CategoryMicrophone Stand/Boom Combos
    (5 Reviews)
  • Weight6.25 lbs.
View similar products to the JamStands JS-MCTB200 Tripod Mic Stand w/Telescoping Boom
in the Microphone Stand/Boom Combos product category.
JamStands JS-MCTB200 Tripod Mic Stand w/Telescoping Boom is rated 3.4 out of 5 by 5.
Rated 4 out of 5 by from Good overall boom micFor the price a good highly adjustable boom mic. Base is solid, adjustments work well. This is a great mic stand for the hobbyist, or weekly player. Three year warranty is a plus. The adjustments seem a little light, had to tighten the locking collars a little more snugly than other makes to keep the boom in place, might just be a new design.
Date published: 2014-11-20
Rated 1 out of 5 by from KEEP LOOKINGWhile initial inspection was impressive after getting my hands on it left a bit to be desired. Had the same problem as a previous reviewer Dumptruck had. Loose crimp to the threaded machined piece that you attache the mike holder to. Also I had a bad resonance when handling the unit. I quickly isolated the cause to the vertical tubes vibrating against each other. The nylon bushing at the bottom of the inner tube was not expanded enough. Contacted PE and they are going to issue a credit and pick-up the return shipping cost. Great customer service. TY Ozzie.
Date published: 2013-11-03
Rated 4 out of 5 by from Great Church Microphone StandThe adjustability of the stand was more than adequate for our needs. The price is excellent, however, I would recommend a more heavy duty stand to provide proper stability for large or heavy microphones.
Date published: 2013-09-02
Rated 4 out of 5 by from Good in the endI think this may be important info for anyone considering this stand. The one I received had a boom where the all-important adapter bolt was cheaply crimped onto the end of the tube, and it spun freely right out of the box, making the stand useless, as a mic would just swing limply below the boom when attached.PE suggested I contact the mfg. before returning. I did, and I could not have been more pleased with their support. They paid to have the defective boom shipped to them, and sent me a new boom the day after they received mine, no charge.The new boom is a much better design that cannot fail in the same way as the one I returned. It also has a more rugged stand-mounting assembly. The mfg. support rep. I spoke to remarked that although this is a current item of theirs, they do not currently make it with crimped connections like the one I received. Other buyers, be advised to find out what you're getting, or be prepared to return a part.With the new boom I received, or disregarding the boom, this stand is a MUCH higher quality overall than other stands in this price range that I have seen in person. I can't say for sure if I've seen any of the other PE offerings in person, specifically. In the end, I'm very pleased with it. It is almost all metal, and easy to use. If there's a weak point, it's that there isn't a heavy weight in the base, but that is true of all cheap stands - you have to add your own if you need one. I find it more than adequate for studio use, and it would probably be fine on stage for most people.
Date published: 2012-01-13
Rated 4 out of 5 by from Great ProductWorks great for my piano player. Great price for a church with a budget.
Date published: 2009-02-10
  • 2016-02-12T06:32CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_242-743, PRD, sort_mostRecent
