iSmartAlarm Preferred Package App Controlled Wireless Security System
Brand:|Part # 335-102
Protect what is important to you, but without expensive installation and monthly fees normally associated with home security systems. The iSmartAlarm Preferred Package includes everything you need to remotely monitor your belongings and loved ones.
Part # 335-102
  • App driven controls for constant monitoring
  • Easy to use plug-and-play hub controls all security system features
  • Wireless door and window sensors can be moved as often as you like
  • Motion sensor detects movement up to 30 ft. and alerts you immediately when triggered
  • Remote tags arm/disarm your system and identify members of your household
Finally, a reliable, intuitive security system has emerged that gives you all the flexibility and features of high-priced systems but with a low one-time purchase price. The iSmartAlarm preferred package includes everything you need to keep your belongings and loved ones safe. Installation and use has never been simpler. Use your existing Wi-Fi network to create a security system that you control.
CubeOne Control Hub
The brain of the entire system is the CubeOne. All the components of the iSmartAlarm package communicate wirelessly with the CubeOne hub. The hub then sends data to the cloud so you can access it from the iSmartAlarm app on you smart phone. Installation is simple, just plug the CubeOne into your wireless router and also to a power outlet. It takes one to two minutes to boot, but once it has finished you are ready to start adding the external sensors. It's just that simple; no installation fees and most importantly no monthly costs.
The motion sensor and contact sensors included in your package ensure that important areas of your home are monitored 24/7. Place the motion sensor about 6-1/2 feet from the floor for the best coverage. You can assign a custom label to the motion sensor so you can easily identify it in you app. The contact sensors are equally easy to install. Use the double-sided tape to place one side of the sensor on you door or window and the other side of the sensor on the door jamb or window frame. Like the motion sensor, assign names to each contact sensor to easily identify areas of your home that are now protected.
Remote Tags
Remote tags serve several purposes. They are primarily used to arm or disarm your iSmartAlarm system. Included on the tag is a panic button that engages the CubeOne to sound a 110 dB alarm deterring intruders from entering your home. Another great feature of the remote tag is that it serves as an identifier to members of your family or even your pets. Assign a remote tag to a member of your family, then log into your app to see who is at home, when they arrived or when they left. Keeping tabs on those you love has never been easier.
Customize Your Security Solution
The iSmartAlarm Premium Package has enough sensors and remote tags to get you started, but what if you need more? Don't worry, the system is expandable up to 80 units. That means you can add enough motion sensors, contact sensors, and remote tags to cover your home and loved ones. If you decide that you want to add the iCamera, no problem. You can integrate one camera into the preferred package. Keep in mind that the CubeOne hub can only support one camera at this time. Take a look at the related products on the right side of this page for additions to your iSmartAlarm.
iSmartAlarm Preferred Package Includes
1 CubeOne hub • 1 motion detection sensor • 2 contact sensors • 2 wireless remote tags • 1 CubeOne power supply • 1 network cable • 2 iSmartAlarm window stickers • Quick installation guide • Owner's manual.
  • BrandiSmartAlarm
  • Part Number335-102
  • UPC858176004007
  • Product CategorySurveillance Systems
  • Weight2.7000 lbs.
View similar products to the iSmartAlarm Preferred Package App Controlled Wireless Security System
in the Surveillance Systems product category.
