Intelix VGA2-HR High Resolution VGA over Twisted-Pair Extender Balun Set (1600 x 1200) up to 350 ft.
Brand:|Model: VGA2-HR|Part # 183-645
The Intelix VGA2-HR balun set is able to extend UXGA (1600 x 1200) resolution video up to 350 feet over structured cabling, such as standard Cat 5e / Cat 6 UTP cable.
  • Extends a computer video signal (maximum of 1600x1200) up to 350 feet
  • These baluns replace bulky coax cable by using affordable Cat 5e or Cat 6 wire
  • Dipswitch controlled adjustable color skew equalization
  • Built-in EDID presets for common resolutions (1024x768 and 1280x800 @ 50/60 Hz)
  • Includes transmitter, receiver, and power supply
The Intelix VGA2-HR balun set is able to extend UXGA (1600 x 1200) resolution video up to *350 feet over structured cabling, such as standard Cat 5e / Cat 6 UTP cable. The VGA2-HR features custom dipswitch adjustment, allowing you to eliminate color skew, bleed, and ghosting, problems frequently associated with extended distance VGA distribution. Sold as a complete transmitter and receiver system.
Ideal for corporate facilities, churches, schools, auditoriums and almost any other situation involving VGA video signal distribution. Used in pairs, these baluns replace bulky coax cable and can utilize a building's existing structured cabling network.
Specifications: • Max distance: 350 ft. • Max resolution: UXGA (1600 x 1200) • Power: 12 VDC (power supply included) • Input video signal: 1.2Vp-p • I/O connections: VGA (HD15) female, shielded RJ45 female, and 12 VDC power jack (2.1 x 5.5 mm, "send" unit only) • Included accessories: VGA cable, power supply, adjustment screwdriver, mounting bracket, and installation guide • Enclosure: Painted steel • Dimensions (L x W x H): 3.27" x 2.36" x 0.98" (83 x 60 x 25 mm).
*Distances and picture quality may be affected by cable grade, cable quality, source and destination equipment, RF and electrical interference, and cable patches. Intelix specifications are based on straight-through cabling with standard Cat 5e.
  • Video Input/OutputVGA (HD15)
  • BrandIntelix
  • ModelVGA2-HR
  • Part Number183-645
  • UPC601446000199
  • Product CategoryAudio/Video Extenders over UTP Cat 5e/6 Cable
    (1 Reviews)
  • Weight1.35 lbs.
View similar products to the Intelix VGA2-HR High Resolution VGA over Twisted-Pair Extender Balun Set (1600 x 1200) up to 350 ft.
in the Audio/Video Extenders over UTP Cat 5e/6 Cable product category.
