Intelix AVO-V2A2 Y/C or 2 Composite Video & Audio Balun
Brand:|Model: AVO-V2A2|Part # 183-625
The AVO-V2A2 balun is the perfect solution for transmitting two channels of composite video or a Y/C video signal, and an ultra-high quality stereo audio up to • 2200 feet over structured cabling, such as Cat 5.
  • Simple to use
  • Extend audio / video signals up to 2200 ft.
  • Uses affordable Cat 5 wire
  • Perfect for residential or commercial installs
  • Easy to install
The AVO-V2A2 balun is the perfect solution for transmitting two channels of composite video or a Y/C video signal, and an ultra-high quality stereo audio up to • 2200 feet over structured cabling, such as Cat 5. Used in pairs, AVO-V2A2 baluns replace bulky coaxial cable and utilize a building's existing structured cabling network. Two AVO-V2A2’s are needed for a complete system, one to transmit and one to receive. No power is needed. Sold individually. • Distances and picture quality may be affected by cable grade, cable quality, source and destination equipment, RF and electrical interference, and cable patches. Intelix specifications are based on straight-through cabling with standard-grade Cat 5.
Specifications: • Max distance: 2200 ft. • Bandwidth: Video: DC to 8 MHz, Audio: 20 Hz to 20 kHz • Power: No power required • Maximum input: 1.1 Vp-p • Insertion loss: <2 dB over the frequencies from DC to 8 MHz • Return loss: Better than 15 dB over the frequency range from DC to 8 MHz • Common mode rejection: <40 dB @ 8 MHz • Impedance: Video: 75 ohms, Audio: 600 ohms • Cable: Cat 5, Cat 5e, Cat 6, and Cat 7 compatible • Connectors: (4) RCAs to one (1) RJ45 • Pin out: Video 1: 7 & 8, pair 4, Video 2: 4 & 5, pair 1, Audio 1: 1 & 2, pair 2, Audio 2: 3 & 6, pair 3 • Dimension: 4.3" H x 2.5" W x 1" D.
  • Audio Input/OutputL/R Analog
  • Video Input/OutputComposite
  • BrandIntelix
  • ModelAVO-V2A2
  • Part Number183-625
  • UPC895857001160
  • Product CategoryAudio/Video Extenders over UTP Cat 5e/6 Cable
    (1 Reviews)
  • Weight1 lbs.
View similar products to the Intelix AVO-V2A2 Y/C or 2 Composite Video & Audio Balun
in the Audio/Video Extenders over UTP Cat 5e/6 Cable product category.
