Intelix AVO-SVA2 S-Video & Stereo Audio Balun
Brand:|Model: AVO-SVA2|Part # 183-615
The AVO-SVA2 balun is a perfect solution for transmitting s-video and ultra-high quality stereo audio up to • 1000 feet over structured cabling, such as Cat 5.
- Order Soon - Only 3 Left In Stock
List Price$113.94
You Save15%
$96.85
Part # 183-615
  • Simple to use
  • Extend signals up to 1000 ft.
  • Uses affordable Cat 5 wire
  • Perfect for residential or commercial installs
  • Easy to install
The AVO-SVA2 balun is a perfect solution for transmitting s-video and ultra-high quality stereo audio up to • 1000 feet over structured cabling, such as Cat 5. Used in pairs, AVO-SVA2 baluns replace bulky coaxial cable and utilize a building's existing structured cabling network. Two AVO-SVA2’s are needed for a complete system, one to transmit and one to receive. No power is needed. Sold individually. • Distances and picture quality may be affected by cable grade, cable quality, source and destination equipment, RF and electrical interference, and cable patches. Intelix specifications are based on straight-through cabling with standard-grade Cat 5.
Specifications: • Max distance: 1000 ft. • Bandwidth: Video: DC to 6 MHz, Audio: 20 Hz to 20 kHz • Power: No power required • Video impedance: 75 ohms • Audio impedance: 600 ohms min • Max input: 1.1V p-p • Insertion loss: Video: < 2 dB per pair over the frequency range, Audio at 600 ohms: <3 dB per pair, Audio at 1.2k Ohms: <1.9 dB per pair • Return loss: Better than 15 dB over the frequency range • Common mode rejection: >40 dB over the frequency range • Cable: Cat 5, Cat 5e, Cat 6, and Cat 7 compatible • Connectors: (1) female 4-pin mini DIN, two (2) RCA audio jacks, and one (1) RJ45 • Pin out: S-video Luma: 7 & 8, pair 4, S-video Chroma: 4 & 5, pair 1, Audio Channel 1: 1 & 2, pair 2, Audio Channel 2: 3 & 6, pair 3 • Dimensions: 4.3" H x 2.5" W x 1" D.
  • Audio Input/OutputL/R Analog
  • Video Input/OutputS-Video
  • BrandIntelix
  • ModelAVO-SVA2
  • Part Number183-615
  • UPC895857001092
  • Product CategoryAudio/Video Extenders over UTP Cat 5e/6 Cable
    (2 Reviews)
  • Weight1 lbs.
View similar products to the Intelix AVO-SVA2 S-Video & Stereo Audio Balun
in the Audio/Video Extenders over UTP Cat 5e/6 Cable product category.
Intelix AVO-SVA2 S-Video & Stereo Audio Balun is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from Great ChoiceIt was nice to to buy something and have it work with no complications. Just took it out of the package and plugged it in and had video and audio over a 350+ ft run of cat5. It definitely performs as advertised.
Date published: 2012-05-14
Rated 4 out of 5 by from Great ProductUsed this product at church to quickly run a temporary 150 foot feed from one building to another when we needed an overflow room for an event. This worked so well, we are now considering running the line in permanently. Audio was sent from a mixing board while video came from a camera and a DVD player (we used a video switch box to select the input). At the destination sound went to an amplifier and the video to the projector. Both were synced up and looked as good as they did in the main auditorium.
Date published: 2010-03-17
  • 2016-05-03T06:29CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_183-615, PRD, sort_mostRecent
