Intelix AVO-A4-F 4 Mono or 2 Stereo Audio Balun
Brand:|Model: AVO-A4-F|Part # 183-605
The Intelix AVO-A4 is an ultra-high performance audio balun designed for applications where audio quality is critical, such as high-end residential and broadcast. The A4 transmits audio signals up to *2500 ft.
List Price$120.95
You Save15%
$102.81
Part # 183-605
  • Simple to use
  • Extend stereo signals up to 2500 ft.
  • Uses affordable Cat 5 wire
  • Perfect for residential or commercial installs
  • Easy to install
The Intelix AVO-A4 is an ultra-high performance audio balun designed for applications where audio quality is critical, such as high-end residential and broadcast. Used in pairs, the AVO-A4 is the perfect solution for transmitting four channels of analog audio (4 mono or 2 stereo) over structured cabling, such as Cat 5. Simply place an AVO-A4 at each end of your cable run and connect your source and destination devices. The A4 transmits audio signals up to • 2500 ft. Two A4’s are needed for a complete system, one to transmit and one to receive. No power is needed. • Distances and picture quality may be affected by cable grade, cable quality, source and destination equipment, RF and electrical interference, and cable patches. Intelix specifications are based on straight-through cabling with standard-grade Cat 5.
Specifications: • Max distance: 2500 ft. • Bandwidth: 20 Hz to 20 kHz • Power: No power required • Impedance: 600 ohms, unbalanced to balanced • Isolation: 500 V • Nominal level: 1.0 V • Insertion loss: 1 dB • Common mode rejection: >40 dB • Cable: Cat 3, Cat 5, Cat 5e, Cat 6, and Cat 7 compatible • Connectors: four RCA to one RJ45 • Pin out: Channel 1 (L): 4 & 5, pair 1, Channel 1 (R): 1 & 2, pair 2, Channel 2 (L): 3 & 6, pair 3, Channel 2 (R): 7 & 8, pair 4 • Dimensions: 4.3" H x 2.5" W x 1" D.
  • Audio Input/OutputL/R Analog
  • BrandIntelix
  • ModelAVO-A4-F
  • Part Number183-605
  • UPC895857001030
  • Product CategoryAudio/Video Extenders over UTP Cat 5e/6 Cable
  • Weight1 lbs.
VGA Balun RJ45 to HD15 1 Pair
Part #  335-378
Intelix AVO-A2-F Stereo Audio Balun
Part #  183-600
Balun RJ45 Jack to 2 x RCA Female
Part #  183-332
View similar products to the Intelix AVO-A4-F 4 Mono or 2 Stereo Audio Balun
in the Audio/Video Extenders over UTP Cat 5e/6 Cable product category.
