183-605_ALT_0
Intelix AVO-A4 4 Mono or 2 Stereo Audio Balun
Brand:| Model: AVO-A4
The Intelix AVO-A4 is an ultra-high performance audio balun designed for applications where audio quality is critical, such as high-end residential and broadcast. The A4 transmits audio signals up to *2500 ft.
  • Simple to use
  • Extend stereo signals up to 2500 ft.
  • Uses affordable Cat 5 wire
  • Perfect for residential or commercial installs
  • Easy to install
183-605
Weight: 1 lbs.
OUT OF STOCK
Due In: 7/31/2014
List Price$87.95
You Save13%
$75.64
Part # 183-605
The Intelix AVO-A4 is an ultra-high performance audio balun designed for applications where audio quality is critical, such as high-end residential and broadcast. Used in pairs, the AVO-A4 is the perfect solution for transmitting four channels of analog audio (4 mono or 2 stereo) over structured cabling, such as Cat 5. Simply place an AVO-A4 at each end of your cable run and connect your source and destination devices. The A4 transmits audio signals up to • 2500 ft. Two A4’s are needed for a complete system, one to transmit and one to receive. No power is needed. • Distances and picture quality may be affected by cable grade, cable quality, source and destination equipment, RF and electrical interference, and cable patches. Intelix specifications are based on straight-through cabling with standard-grade Cat 5.
Specifications: • Max distance: 2500 ft. • Bandwidth: 20 Hz to 20 kHz • Power: No power required • Impedance: 600 ohms, unbalanced to balanced • Isolation: 500 V • Nominal level: 1.0 V • Insertion loss: 1 dB • Common mode rejection: >40 dB • Cable: Cat 3, Cat 5, Cat 5e, Cat 6, and Cat 7 compatible • Connectors: four RCA to one RJ45 • Pin out: Channel 1 (L): 4 & 5, pair 1, Channel 1 (R): 1 & 2, pair 2, Channel 2 (L): 3 & 6, pair 3, Channel 2 (R): 7 & 8, pair 4 • Dimensions: 4.3" H x 2.5" W x 1" D.
  • Audio Input/OutputL/R Analog
  • BrandIntelix
  • ModelAVO-A4
  • Part Number183-605
  • UPC895857001030
  • Product CategoryA/V over Twisted Pair Baluns
  • Weight1 lbs.
View similar products to the Intelix AVO-A4 4 Mono or 2 Stereo Audio Balun
in the A/V over Twisted Pair Baluns product category.
Customer projects that include: Intelix AVO-A4 4 Mono or 2 Stereo Audio Balun
