Intelix AVO-A2-F Stereo Audio Balun
Brand:|Model: AVO-A2-F|Part # 183-600
The Intelix AVO-A2 is an ultra-high performance audio balun designed for applications where audio quality is critical, such as high-end residential and broadcast. Used in pairs, the AVO-A2 is the perfect solution for transmitting two channels of analog audio up to *2500 ft.
OUT OF STOCK
Awaiting Updated Due Date
List Price$80.95
You Save15%
$68.81
Part # 183-600
  • Simple to use
  • Extend stereo signals up to 2500 ft.
  • Uses affordable Cat 5 wire
  • Perfect for residential or commercial installs
  • Easy to install
The Intelix AVO-A2 is an ultra-high performance audio balun designed for applications where audio quality is critical, such as high-end residential and broadcast. Used in pairs, the AVO-A2 is the perfect solution for transmitting two channels of analog audio up to *2500 ft. over structured cabling, such as Cat 5. Simply place an AVO-A2 at each end of your cable run and connect your source and destination devices. Two AVO-A2’s are needed for a complete system, one to transmit and one to receive. No power is needed. *Distances and picture quality may be affected by cable grade, cable quality, source and destination equipment, RF and electrical interference, and cable patches. Intelix specifications are based on straight-through cabling with standard-grade Cat 5.
Specifications: • Max distance: 2500 ft. • Bandwidth: 20 Hz to 20 kHz • Power: No power required • Impedance: 600 ohms, unbalanced to balanced • Isolation: 500 V • Nominal level: 1.0 V • Insertion loss: 1 dB • Common mode rejection: >40 dB • Cable: Cat 3, Cat 5, Cat 5e, Cat 6, and Cat 7 compatible • Connectors: (2) RCA to one (1) RJ45 • Pin Out: Channel 1: 1 & 2, pair 2, Channel 2: 3 & 6, pair 3 • Dimensions: 4.3" H x 2.5" W x 1" D.
  • Audio Input/OutputL/R Analog
  • BrandIntelix
  • ModelAVO-A2-F
  • Part Number183-600
  • UPC601446156483
  • Product CategoryAudio/Video Extenders over UTP Cat 5e/6 Cable
  • Weight1 lbs.
View similar products to the Intelix AVO-A2-F Stereo Audio Balun
in the Audio/Video Extenders over UTP Cat 5e/6 Cable product category.
