073-077_ALT_0
073-077_ALT_1
073-077_ALT_2
073-077_ALT_3
073-077_ALT_4
073-077_ALT_5
073-077_ALT_6
Individual Red Green and Blue SMD 3528 LEDs 5m Tape Lighting Strip 12 VDC Waterproof 100 Each Color
Brand:| Model: DC-LE12122
Decorate your home, office, or car with 12V LED strip lighting. IP65 waterproof rated for indoor and outdoor use. 100 red, green, and blue LEDs are at your disposal. Use the whole 5 meter roll or cut the LED strip in 6" increments to a custom length.
  • 100 red, 100 green, and 100 blue 3528 surface mount LEDs on a single strip
  • Longer life and lower power consumption compared to rope lights
  • Flexible IP65 waterproof coating
  • Unlimited placement options with aggressive adhesive backing
073-077
Weight: 0.5 lbs.
IN STOCK
List Price$39.99
You Save33%
$26.90
Buy 4-up$25.60
Part # 073-077
These RGB LED tape strips are built with 9 bright, single-color 3528 surface mount LEDs (3 red, 3 green, and 3 blue) per every 6" for the great color density, 300 total. These strips are great for use as indoor strip lighting or illuminating a display case. Connecting multiple strips together is made quick and simple with solder tabs on the end of each segment. Aggressive adhesive is affixed to the back of the strip for permanent mounting.
Each strip is marked with cut lines for creating a custom length strip, or up to 32 6" strip segments with nine LEDs per section (3 red, 3 green, and 3 blue). Each section features four solder points (voltage +, green, red, and blue) to create many different color combinations and for easy daisy-chaining.
To facilitate ease of use, voltage dropping resistors are built-in. Simply connect a 12 VDC power supply (up to a 12 VDC, 6A power supply is recommended and sold separately) to the solder points and go! Additionally, you can use either the 24 or 44-key remote control LED control unit for color control or to create amazing effects. Each strip is pre-terminated with a 4" pigtail for connection to an LED control unit (sold separately). CE and RoHS compliant. IP65 waterproof-rated for outdoor use.
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 2A • Overall dimensions (W x L x H): 0.44" x 196.80" x 0.125" (11 x 5000 x 3.2 mm) • Segment length: (32 segments per strip, 3 LEDs of each color per segment): 6".
LED Specifications: • LED type: SMD 3528 • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens • Dimensions (L x W x H): 3.5 x 2.8 x 2.0 mm.
  • BrandParts Express
  • ModelDC-LE12122
  • Part Number073-077
  • UPC848864000275
  • Product CategoryAccent & Party Lighting
  • Weight0.5 lbs.
View similar products to the Individual Red Green and Blue SMD 3528 LEDs 5m Tape Lighting Strip 12 VDC Waterproof 100 Each Color
in the Accent & Party Lighting product category.
Do you have just a white led? Or white and blue? I was thinking of putting it on my fish tank. It would be mounted on top of a plexi clear top.
Asked by: brush
We do offer a strip with white LED's only, although it is only available in 20" lengths. If you want white and blue, I would recommend a standard RGB strip like this.
Date published: 2014-11-26
What is the different between SMD 5050 and 3528 ?
Asked by: Ninja
The 3528 LED's are individually colored with either red, green or blue. The 5050 LED's are tricolor LED's, so they each have all three colors in each LED.
Date published: 2014-11-06
I am looking to install these around my pool.  A total run of 90 feet.  After purchasing 6x5M sets, will I need another power supply to run these lights?  Also, what are the connectors that I will need in order to join them? Thank You!
Asked by: Bigelito
Date published: 2014-08-25
I'm considering ordering up 3 'rolls' of the 5 meter tapes to be in a few areas of my home. (Above my kitchen cabinets and in my livingroom around my two bay windows) Will I need more than ONE controller to service these?
Asked by: Jlulu
You can power three 5 meter strips with a high powered controller and a minimum of a 12 amp power supply.
Date published: 2014-02-06
Is it possible to purchase the 4C connector?
As comes on the end (beginning) of the strip?Both male and female.
Asked by: FCWC
Unfortunately we do not offer these separately at this time.
Date published: 2013-02-05
How much wire can be added?
My project requires me to divide this strip up into 6 strips. I have to add 4 wire connections in 6 positions totaling 163" of added wire. When it is done the total length (including light strip) will be 30 feet long. Will one 12 Volt power source work? What gauge wire works best?
Asked by: Billbob
What you have planned will work fine. I would recommend something like 18-22 gauge cable for the best results.
  • 2015-03-28T07:23CST
  • co_hasquestionsanswers, tq_8
  • loc_en_US, sid_073-077, PRD, sort_recentQuestionsFirst
Customer projects that include: Individual Red Green and Blue SMD 3528 LEDs 5m Tape Lighting Strip 12 VDC Waterproof 100 Each Color
