240-412_ALT_0
In-Line XLR Attenuator Pad 10dB
Brand:|Part # 240-412
An attenuator or pad will reduce the overall signal level while maintaining the input and output impedance. 3-pin XLR-M to 3-pin XLR-F. Attenuation: 10 dB.
List Price$12.99
You Save24%
$9.90
Buy 5+$9.40
Part # 240-412
Some audio devices will overdrive an audio input whether by design or by accident. Mixing consoles in theaters are often designed to output a 3 volt signal that can overdrive the 1 volt input of a studio mixing console. An attenuator or pad will reduce the overall signal level while maintaining the input and output impedance. Simple inline connection allows the attenuators to be ganged together to reach the desired attenuation level. 3-pin XLR-M to 3-pin XLR-F. Attenuation: 10 dB.
  • BrandParts Express
  • Part Number240-412
  • UPC844632075032
  • Product CategoryXLR Adapters
    (3 Reviews)
  • Weight0.105 lbs.
View similar products to the In-Line XLR Attenuator Pad 10dB
in the XLR Adapters product category.
In-Line XLR Attenuator Pad 10dB is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Works GreatBought seven of these (one for each channel) so Audyssey would not set all my Klipsch speakers to -12 db. I am using Emotiva Amps.
Date published: 2014-08-07
Rated 5 out of 5 by from Valuable Quick Fix To Control Audio Level. A Must Have In The Audio Engineer's "Bag Of Tricks".I have found these to be extremely valuable in the field and at the studio when you want to quickly pad down the audio level feeding equipment. In our less than perfect world, the output level of a device is sometimes higher than the interconnected equipment input needs. These in line pads provide excellent attenuation and they are manufactured at different values to match just the right attenuation needed.
Date published: 2013-10-09
Rated 5 out of 5 by from Essential for Digital RecordingThis product does exactly what it's supposed to do. If you're doing digital recording off a mixer board or any other line-level source, attenuators are essential to avoid distortion due to overdriving. 10dB seems to be a bit low for my ZOOM H4 recorder. 20dB works better. Different sizes might be more suitable for other gear. 15's are also available.
Date published: 2011-10-14
  • 2016-02-08T06:37CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_240-412, PRD, sort_mostRecent
