090-442_ALT_0
090-442_ALT_2
IEC Power Jack Chassis Mount
This IEC power jack is perfect for replacement, DIY projects or converting older equipment, so they can be used with IEC style power cords. It is constructed out of high temperature, impact resistant UL94V-0 plastic.
090-442
Weight: 0.1 lbs.
IN STOCK
$1.97
Buy 4-up$1.52
Part # 090-442
This IEC power jack is perfect for replacement, DIY projects or converting older equipment, so they can be used with IEC style power cords. It is constructed out of high temperature, impact resistant UL94V-0 plastic. The heavy gauge contacts are made of nickel plated brass and will accept solder or .187" quick disconnects. Contact rating: 10A, 250VAC. Overall dimensions: 2" x 7/8". Cut out dimensions: 1-1/16" x 3/4". UL and CSA listed.
  • ConfigurationIEC
  • Power Connector TypeChassis / Panel Mount
  • Current Rating10A
  • BrandParts Express
  • Part Number090-442
  • UPC844632005152
  • Product CategoryAC Power Connectors
    (22 Reviews)
  • Weight0.1 lbs.
View similar products to the IEC Power Jack Chassis Mount
in the AC Power Connectors product category.
IEC Power Jack Chassis Mount is rated 4.7727 out of 5 by 22.
Rated 4 out of 5 by from Good, cheapThis is a perfectly good jack. It fits well, and is an easy hook-up. The holes in the post on the back are big enough for a reasonably thick wire.One thing though, this is a very small part, and yet it arrived in an 8 inch by 12 inch envelope, which wasn't even recyclable. The world's changing, time to catch up.
Date published: 2014-09-19
Rated 5 out of 5 by from exactly what I neededI used two of these chassis mount power plugs as soon as the arrived. One went to replace a plug I had broken and the other to update an old piece of test gear which used the round three pin power cord. The second took a little chassis modification to hold the new plug (easy work with a Dremel Tool), and now all of my equipment uses the current type removable AC power cords! I got a couple of extras to help my friends out, too!
Date published: 2014-09-15
Rated 5 out of 5 by from As exoected.Thus is such a simple item, it seems absurd to write a review. It is as expected.
Date published: 2014-09-06
Rated 4 out of 5 by from IEC Power jack moundI purchased this for my pedalboard because it was the cheapest one I could find. It works well.
Date published: 2014-01-30
Rated 4 out of 5 by from No screwsWorks great. Package does not come with mounting screws
Date published: 2013-08-08
Rated 5 out of 5 by from It's What You NeedIf this is the kind of jack you need, then this is the jack for you. No jacking around Jack, this is a great jack. Srsly tho, very sturdy jack, easy to install, would have been nice if nuts and bolts were included, but no biggie, I have an Ace close to me and took all of 3 minutes to find the right hardware. Quality is good, and of course PE ships like the wind.
Date published: 2012-11-06
What connectors to use?
Which connectors can I use with this product? It says .187" connectors, but I couldn't find those.. Please help.
Asked by: NRG5
3/16" female disconnects are the ones your looking for.3/16 = .1875
Answered by: mtg90
Date published: 2012-01-18
Customer projects that include: IEC Power Jack Chassis Mount
