HiVi D8.8 8" Poly Bass/Midrange Shielded
Brand:|Model: D8.8|Part # 297-449
The HiVi D8.8 is an excellent 8" woofer for high power "no compromise" audiophile speaker systems. It may also be used as a subwoofer in various configurations.
List Price$303.99
You Save42%
$175.98
Buy 4-23 $165.99
Buy 24+$157.90
Part # 297-449
  • Shallow mineral-filled polypropylene cone
  • Fatigue resistant foam surround
  • Shielded vented magnet system with a huge neodymium magnet
  • Long-throw symmetrically driven motor structure
  • Extreme power handling voice coil with a 100 mm black anodized aluminum former
  • High density aluminum die-cast frame
  • Progressive spider with decompressed rear volume
The HiVi D8.8 woofer's voice coil is positioned over an undercut pole piece with a large thermally stabilized neodymium magnet at the bottom and a high energy ceramic magnet on the top. A specially shaped, CNC-machined steel cup completes the magnetic structure from the outside, creating a shielded magnet system with symmetrical flux density distribution along the gap. The long-throw voice coil experiences a symmetrical driving force that substantially decreases inductance and back electromotive force (EMF) modulations. The magnet structure is optimized using Finite Element Analysis techniques, and the result is a radical improvement of driver linearity. The mineral-filled polypropylene cone has a shallow, high integrity structure, which is extremely rigid and dynamically stable. The vented design and a high temperature rated voice coil provide a dramatic increase in power handling. The HiVi D8.8 is an excellent woofer for high power "no compromise" audiophile systems. It may also be used as a subwoofer in various configurations.
  • Nominal Diameter8"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance8 ohms
  • Frequency Response40 to 2,000 Hz
  • Sensitivity86 dB 2.83V/1m
  • Voice Coil Diameter3.9"
  • Resonant Frequency (Fs)30 Hz
  • DC Resistance (Re)6.5 ohms
  • Mechanical Q (Qms)4.36
  • Electromagnetic Q (Qes)0.44
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)1.33 ft.³
  • Mechanical Compliance of Suspension (Cms)0.46 mm/N
  • Diaphragm Mass Inc. Airload (Mms)53.1g
  • Maximum Linear Excursion (Xmax)8.3 mm
  • Surface Area of Cone (Sd)241 cm²
  • Cone MaterialPoly
  • Surround MaterialFoam
  • Voice Coil Wire MaterialCCA
  • Voice Coil FormerAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter9.53"
  • Baffle Cutout Diameter7.94"
  • Depth4"
  • # Mounting Holes12
  • Sealed Volume0.38 ft.³
  • Sealed F367 Hz
  • Vented Volume1.07 ft.³
  • Vented F338 Hz
  • BrandHiVi
  • ModelD8.8
  • Part Number297-449
  • UPC844632021862
  • Product CategoryWoofers
    (3 Reviews)
  • Weight7.75 lbs.
View similar products to the HiVi D8.8 8" Poly Bass/Midrange Shielded
